Customs Joe Hunt Mag-look distributor problem
Discussion in 'The Hokey Ass Message Board' started by Craig Nitta, Jun 10, 2016.
  1. Craig Nitta
    Craig Nitta
    Good day to all,
    New to the H.A.M.B. First posting.
    I'm having some problems with a Joe Hunt mag-look electronic distributor that i am currently installing on an 8BA flathead engine. I had it all wired in as per instructions and the engine fired up. It had been running for @5 mins and i was just about to set the timing, and it shut down. Now have no spark whatsoever. Anyone out there experience the same problem? Or can anyone direct me to the proper thread that discusses other instances like this or a possible solution? Thanks in advance for the help, and looking forward to being a part of the community.
  2. CheatersPete
    CheatersPete
    module or internal coil , lot of issues were raised on the HAMB, use the search fonction
    lothiandon1940 likes this.
  3. X38
    X38
    I'll save you all the pain of doing searches: take it out and put in a proper distributor.
    This is a fake idea that is not only a fake, they have a very poor history of actually working.
    Countn'Carbs and lothiandon1940 like this.
  4. jrsiron
    jrsiron
    Don't waste your money getting it repaired. It will just take another **** after spending money getting it repaired by Joe Hunt. Just sit on your shelf and tell anyone about it that is thinking about it that is going to buy anything from Joe Hunt
    busted49ford likes this.
  5. ididntdoit1960
    ididntdoit1960
    from Western MA
    The solution is to get the coil out of the distributor.....the unit is too compact and the coil is too close to the module/electronics......if you cant do it yourself, Bubba does it. Once set up this way they are reliable and work fine....its basically a gm HEI
    LAROKE likes this.
  6. Who is Bubba?
  7. alchemy
    alchemy
    Bubba Linder was the expert old Ford distributor rebuilder who has recently retired.
