Projects Jokermobile
Discussion in 'The Hokey Ass Message Board' started by BatRestorer, Dec 18, 2017.
  1. They look like green line Stewart Warner with bad lenses. They are being Re-popped by Stewart Warner
    [​IMG][​IMG]
    49ratfink likes this.
  2. BatRestorer
    BatRestorer
    from New Jersey
    Great info. Gauges should be easy. Thank you!
  3. BatRestorer
    BatRestorer
    from New Jersey
    Any ideas on what that Go-Go ****on came from?
  4. Those gauges came out in the early 60's maybe the very late 50's and were very popular to the early 70's.
    Which would be the time frame the car was built.
  5. No, maybe some kind of mod era toy?
  6. Chris
    Chris
    I have one of those scoops used on that bat wing air cleaner (no pun intended), but only one...
  7. BatRestorer
    BatRestorer
    from New Jersey
    Thanks Chris but I already scored two of those scoops. Got the Batwing too. No idea where I'd find those valve cover covers so probably going to make those.
  8. Terrible80
    Terrible80
  9. I wounder if they are a raw (unfinished) casting for a 331 Caddy maybe a 324 or 371 Olds with center valve cover bolts that were never drilled?
    Very similar look to these Weiand for a 303 324
  10. BatRestorer
    BatRestorer
    from New Jersey
    Made by Sears..close but no cigar:
  11. eticket
    eticket
    Why not get a hold of Gene W. and maybe build the Catwoman, Bewitched, star trek car? :) catcar.jpg cat car2.png
  12. Yup, those look like badly faded/foggy Stewart Green Line gauges
  13. traffic61
    traffic61
    from Owasso, OK
    image.jpeg King Tut's groovy gilded go getter is what really needs to be replicated!
    abe lugo and anthony myrick like this.
  14. BatRestorer
    BatRestorer
    from New Jersey
    Funny, I was just talking to a friend this morning about the Reactor. Apparently the original was shown at Concourse d' Elegance in Pebble Beach last August. It was also in Mission Impossible in addition to the other shows you mentioned. It would be hard to replicate that car..unless you actually could get Gene to do it. Not something he'd probably do at 90 years old. Maybe it could be modified from a Corvette?
  15. Moriarity
    Moriarity
    SUPER MODERATOR
    I think those are dixco gauges. Stewart warners never had plastic lenses to turn cloudy like that and if you really look the the pointer comes from the bottom center right where the S/W logo would be...[​IMG][​IMG]
    Tim_with_a_T and tb33anda3rd like this.
  16. Holy New Old Stock Batman!!!
    How do you find this stuff?
    tb33anda3rd likes this.
  17. Moriarity
    Moriarity
    SUPER MODERATOR
    decades of unsupervised buying at swap meets....
  18. BatRestorer
    BatRestorer
    from New Jersey
    Great detective work Moriarity. I didn't notice that the underlying face of the gauges were somewhat visible under the foggy lens. The middle one of the cluster of 3 looks like it might be an amp gauge. Amps is the only gauge in the cluster of 3 where the needle rests at the midline position. I can just barely see some numbers under there. I agree they are more likely to be Dixco than SW based on the origin of the pointer. But the ring is slightly different than the one pictured so it might be Dixco but from a different time period.
    Moriarity likes this.
  19. BatRestorer
    BatRestorer
    from New Jersey
    On the other hand could it be these SW gauges? The needles are in the midline location and the outer rings look like they match better.
  20. Moriarity
    Moriarity
    SUPER MODERATOR
    could be, but i don't think Stewart Warner gauges ever had a plastic lense, only gl***....
  21. Kinda crazy...just stumbled across this article in Jan. 1984 Popular Hot Rodding. Gene. barris 001.JPG
  22. Tim_with_a_T
    Tim_with_a_T
    ^^^I'm with you on this one.... kinda. I've had many Greenlines in my hands and they never looked like that. Although the bezels in the Jokermobile thing do not look like those Dixco. I couldn't find a better photo, but to me, they look like Greenline knock-offs....EDIT: it appears they are a derivative of the Dixco gauges you posted. I've had a couple of these over the years, and my gut says that's what they were.
  23. Tim_with_a_T
    Tim_with_a_T
    Bat, look again at the bezels. The 90* sweep Stewart Warner Greenline gauges that you posted have slightly different bezels than the 270* sweep bezel Greenlines posted earlier. I think they're the Dixco ones in the picture above. I like what you're doing. The Bat-Boat is BA!
  24. BatRestorer
    BatRestorer
    from New Jersey
    Tim, Glad you like the BB. You and Moriarity are absolutely correct about these gauges. The fact that SW only used gl*** knocks them out of the running right there. The Dixco knock offs are a perfect match. if you look at the Ampere gauge there is a slight crescent cut out from the white circle at 6 o'clock. Careful inspection of the middle gauge (on the cluster of 3) on the ****rel shows that it also has this crescent.
    Excellent! Thanks to everyone for the help. Now I just have to find those knock off gauges.
    Tim_with_a_T likes this.
  25. Good call on the Dixco with the plastic lenses... was wondering how/why Stewarts could end up looking like that :D!
