Technical Judson Supercharged Flathead
Discussion in 'Traditional Hot Rods' started by L76, Jun 10, 2021.
  1. L76
    L76
    Just finished flathead build. Engine runs strong normally aspirated. I have 2 Judson super chargers. Trying to get either of them working. No luck. Anyone have experience w/these Judsons? Could use some guidance…
    Cheers,
    L76
  2. L76
    L76
    Some images of the motor…
    kidcampbell71 likes this.
  3. mgtstumpy
    mgtstumpy
  4. L76
    L76
    Thx. MGTSTUMPY. Cool articles. It’d be great to connect with you (that your Ardon/Judson motor?). As best I can tell... I have everything setup right, but just can’t get it running. Ran great with just the carb and intake though.
    -L76
  5. TCTND
    TCTND
    Be sure it's turning the right direction; vanes pointing towards direction of rotation. Not directly on topic, but Judsons must be continuously lubed or the vanes will wear out in short order. When new they came with a pre-oiler.
    VANDENPLAS likes this.
  6. jimmy six
    jimmy six
  7. L76
    L76
    Thx TCTND! Got the marvel mystery oiler hooked up. Vanes & rotation appear to be correct. Can't even get it started, so no vaccuum will pull oil yet. What'd you guys use for vanes? Material?
    -L76
  8. L76
    L76
    Also - there is a ****erfly valve at the base where the blower feeds into the intake. Wondering the positioning of the ****erfly WRT carb / linkage? Might act like a choke. Certainly designed to restrict/control air & fuel. My problem must be air/fuel since the same carb and intake run just fine without the blower.
    -L76
  9. TCTND
    TCTND
    The ****erfly at the base is intended to prevent the blower from seeing a lot of vacuum when you lift off or coast down a mountainside. As long as it's mostly (but not entirely) closed at idle it will be fine. It could be fully open the rest of the time without ill effects. I don't think most kits even came with one so I doubt it was a problem, but someone out there surely knows more about them than I do.
    P
  10. TCTND
    TCTND
    The vanes were made of a phenolic material like bakelite or micarta.
  11. L76
    L76
    So ****erfly position should not inhibit it from starting. Wonder if there is some sort of vaccuum leak in the system... can't figure out why she won't start.
    -L76
  12. TCTND
    TCTND
    It will if it's closed. I'd disconnect it from the throttle linkage, wire it open, and see what happens.
  13. greybeard360
    greybeard360
    I don't see how the linkage on the carb will open the throttle from the angle it is at. Not sure how you have that all set up but just doesn't look right from this point ofview.
  14. Harv
    Harv
    from Sydney
    Judsons are very similar to the Aussie Wray and Norman superchargers. Vanes are typically bakelite, though later units used more modern materials (like Ferroform F76, a thermoset resin used in quite a few milk industry vacuum pumps). Bakelite is a cotton reinforced thermoset. Be wary of using fibregl***... the gl*** fibres are harder than the blower casing liner, and will "sand" it away. The cotton in Bakelite does not.
    Unusual to have a ****erfly between huffer and cylinder head. The Norman Deluxe Type 45/75/90 superchargers did though. The ****erfly was a simple swinging plate. At low revs the supercharger provides very little pressure, and the inlet manifold goes into vacuum (just like a naturally aspirated car). There is very little vacuum at the ****-through carb due to the restriction of p***ing through the lazily-spinning supercharger. The poor carb has low vacuum signal, and is also trying to fight fuel dropout in the slow spinning huffer. To combat this, the ****erfly closes, opening up a p***age directly between the carb and cylinder head. The carb then gets great vacuum signal and no fuel dropout.
    Your starting problem may well be that at low revs you have little carb ****. The supercharger casing and piping is all full of air. Try priming the casing/piping with some aerostart.
    Cheers,
    Harv
  15. Harv
    Harv
    from Sydney
  16. 97
    97
    Damn that's awesome
    I thought I wanted to find another Judson, Now I know I am looking for a Norman.
    Years ago we had a Judson on a Commer truck, ( 1952 so yes on topic) and had a can of Start Ya ******* :eek:, permanently mounted in a spring clip inside the truck, with a length of industrial pneumatic signal line going directly to the intake manifold. I don't think our American and European friends would probably believe us Antipodeans , even if we put a picture up...most likely get accused of photo-shopping it.
    Only trouble was the truck got addicted to the stuff and instead of being used occasionally, on cold days etc, in the end he just wouldn't start without it! :cool: Engine was replaced with a 283 and the Judson went missing , I have been looking for another one ever since! The problem was actually that the starter fluid had washed the bore , and run the rings dry , we couldn't find another motor or pistons for that one.
    https://www.nulon.com.au/products/aerosols/start-ya-*******-instant-engine-starter
    Jet96, VANDENPLAS and kidcampbell71 like this.
  17. 97
    97
    http://www.judsonguru.com/
    https://www.thesamba.com/vw/archive...dson Supercharger Rebuild by Dave Cormack.pdf
    https://www.thesamba.com/vw/archives/lit/judson/installation/Judson Flathead Ford Installation Instructions.pdf
    https://www.thesamba.com/vw/archives/lit/judson/tech/2000 Torlon Vanes - Compressor Tech.pdf
  18. gary macdonald
    gary macdonald
    Yup try starting fluid to prime it . If she fires see if you can get the fuel to keep it running . If it pops or backfires youll be able to see a vacuum leak usually.
  19. Harv
    Harv
    from Sydney
    Awesome feature number 2: the Deluxe Norman superchargers were clutched. That red round thing at the front of my picture is a clutch set, driven by hydraulic pressure. The black hoses tap into engine oil (off the cam gallery) and use oil pressure to push/pull the clutch (almost zero flow of oil so it does not rob the bearings). The clutch disengages/engages the blower pully.
    So driving down the road in a sedate vehicle, flip the switch and suddenly the blower turns on. Mad Max would be proud.
    Wonder why you'd ever turn if off though? :D
    Cheers,
    Harv
  20. 97
    97
    Damn I would love to see some pictures of your grey motor with all the goodies! What sort of crossflow head? Years ago I had a wrecking business , I s****ped the grey motors when I coulda/shoulda kept them . I had no idea how iconic those motors were. A mate came by one day asking for parts, he nearly cried when I told him I had s****ped them, he needed one (probably all of them) for a vintage midget he was restoring.
    Now that I have seen how well Spanners' motor goes in his HA/GR I am really kicking myself.
    Jet96 likes this.
  21. hemihotrod66
    hemihotrod66
    I have a 671 blown hemi and my car will run with the blower not hooked up...You must have a major manifold leak somewhere....
  22. Harv
    Harv
    from Sydney
    Plan is for a reproduction Repco crossflow head, McGee injection, Vertex magneto, Norman supercharger, dry sump, Mitsubishi rods, custom forged pistons. The poor 3-speed crashbox and banjo (LSD centre) will be working hard. Aiming to take the factory 75BHP closer to 200. Jam all that into an FB sedan, and road register it. Nothing like an old hoon :D.
    The head has been on order (deposit laid down) for 3 years. Teaching me patience.
    Cheers,
    Harv
    KiWinUS likes this.
  23. 97
    97
    There was a cheap vertex on a local site here in NZ recently, I thought about it and p***ed it up.
