Technical juice brakes drag when rotating - only one way
Discussion in 'Traditional Hot Rods' started by Ben Chirco, Jul 16, 2025.
  1. Ben Chirco
    Ben Chirco
    I have a 1931 model A truck I bought that needs a lot of work.
    I’m going through all the mechanicals trying to make it road worthy.
    It had juice brakes when I got it. Non functioning.
    I replaced all the brake lines, hoses and cylinders. I also replaced the master cylinder.
    I have bled all the brakes and I have good brakes everywhere.
    I went to adjust the brakes and noticed that the rear brakes adjusters were not moving 1939 to 1942 style.
    So I took the rears apart, cleaned everything up and installed the components.
    I am now ready to adjust the brakes.
    On the driver side rear, when I turn the drum as if I’m going in reverse, the drum rotates very easily.
    When I try to turn the drum as if to be driving forward, there is a lot of drag.
    I can go backwards with no drag.
    If i remove the drum, the axle spins freely both ways.
    My adjusters are not the problem, they are in a loose position.
    I don’t believe it’s the wheel cylinder holding out the brakes because I cannot pull the brake shoes in any closer due to the fact that the emergency brake sets the spread distance of the brake shoes just by design.
    I have done some searches but did not find anything.
