Juice brakes on a Model A ford
Discussion in 'The Hokey Ass Message Board' started by old skool, Oct 31, 2009.
  1. old skool
    old skool
    from VA
    Hello,
    I am on a very tight budget these days (who isn't). I was going to give up, but I decide to push forward. One set back after another. I had to scale down my dreams. I figured some Hot Rod is better than no Hot Rod.
    I want to put juice brakes on my model A roadster. What recommendations does anyone have (low budget, but I want to be safe)? What would work best on an original Model A front and back axle? Anyone have any photos? I also want to try this because it would be a new challenge for me as well. I have installed juice brakes on willys jeeps, but that is what they had. Never did it from scratch. Would a 150 ford drum brakes work? Would an S10? Need some help and some advice from you pros out there. Any websites I could go to?
    Thanks for your time.
    Marty
  2. aldixie
    aldixie
    Do a search on here. Plenty of information, 39 to 48 Ford brakes. Easy to do and they come up cheap. Rebuild parts readily available from O Reily's auto parts.
  3. manyolcars
    manyolcars
    39 to 48 are Lockheed which are NOT self energizing and not self adjusting
    they ****
    you can do better
    I have posted pictures and details many times.
    The HAMB has the most and best info on the web.
    Its a shame there is no index
    Short story, most cars have Bendix brakes, so the parts all interchange (a**** sizes)
    In this pic, the Model A spindles have 1939 Lincoln backing plates with 71-76 Chevy shoes and small parts and 1964 F250 wheel cylinders used with 1940 Ford drums
  4. manyolcars
    manyolcars
    Heres the rear backing plate finished and ready to bolt on.
    In this case, I cut out the chevy center of the 1975 Caprice wagon backing plate and welded in a Ford center that I made on the lathe
    In other words ANY 12" backing plate will work
    Notice the parking brakes and the paint marker identifying the parts for any future owner
