Technical ***July 2025 Banger Meet Thread - Get Your Banger On The Road***
Discussion in 'Traditional Hot Rods' started by Jiminy, Jul 1, 2025.
  1. Deeluxe
    Deeluxe
    from island
    Saw something cool on the weekend.
  2. burl
    burl
    from Minnesota
    Showdown at Sanford Field on 7/12 had great turnout of four cylinders this year sanford 1.jpg sanford 2.jpg sanford 6.jpg sanford 7.jpg sanford 5.jpg sanford 4.jpg
    tractorguy, jet996, 5280A2 and 9 others like this.
  3. Outback
    Outback
    from NE Vic
    Friends of mine have just started producing these, a full front seal conversion. A nice piece. A small job to modify the sump.
    The castings are heat treated also
    Made in Australia
  4. wheeltramp brian
    wheeltramp brian
    very nice front cover.
    winduptoy and Outback like this.
  5. 282doorUK
    282doorUK
    Choose your pan gaskets wisely if you value your sanity and oil pressure.
    I'd fitted this expensive oil pan gasket to my new Burtz engine.
    After a few hundred miles I took the pan off to investigate an alarming tapping noise that had developed and was getting louder.
    Oil pan gasket set A-6781-C for the Ford Model A 1928 to 1931.
    A complete set of all the gaskets needed when removing the oil pan. The cork is a special compound with 90% memory for positive sealing. Torque to 6 foot pounds starting in middle and criss-crossing to front and back ends.
    I replaced the seal with one cut from a cork place mat (hope she'll never notice) just like the old days.
    Tapping now stopped and stress levels restored.
    Seems like that special memory compound can't remember that it's supposed to stay in one piece, keep oil in, not scare the engine builder and not attempt clog up the oil pump!
  6. winduptoy
    winduptoy
    welcome back Martin
    Dirt Drags in Box Elder, South Dakota August 30,31...you outta' go
  7. winduptoy
    winduptoy
    Thank you for posting this...I have the exact same problem and I have a very strong dislike of these gasket sets....
    I knew better than to have my buddy that borrowed a pan gasket set just replace them...he was all proud that he upgraded them for me...I knew better but used them anyway....
    jet996, Savage Coupe and Outback like this.
  8. 282doorUK
    282doorUK
    Did you have the same torn seal causing a ticking noise?
    I posted that same post on a Burtz model A engine FB page and it seems we're not the only ones to have had problems with them.
    Outback likes this.
  9. winduptoy
    winduptoy
    No ticking noise...just copious amount of oil that decides to leave and become dust suppression after the seal tore
    jet996, burl and 282doorUK like this.
  10. Outback
    Outback
    from NE Vic
    This is the new cover fitted to the my mates A, one of the brothers who are producing them
    tractorguy, Old Dawg, jet996 and 8 others like this.
  11. Zax
    Zax
    1. 1952-59 Ford Social Group
    Took it for a test drive Sunday. What a difference!
    I accelerated up a hill! Before it was a struggle just to maintain speed up a hill
    Outback, 282doorUK, Deutscher and 4 others like this.
  12. Outback
    Outback
    from NE Vic
    What comp is the Burtz?
    winduptoy likes this.
  13. Zax
    Zax
    6.5:1
    Outback, Deutscher and winduptoy like this.
  14. winduptoy
    winduptoy
    IMG_20250729_092737051_HDR.jpg getting ready (one persistent oil leak and head gasket leak) for the dirt drags in Box Elder, South Dakota the end of August....30, 31...though I am driving a '31
    anyone else going?
    Three of us from NM and picking up a Colorado boy on the way...
    tractorguy, G Baese, Outback and 2 others like this.
  15. atch
    atch
    You sure don't let any grass grow under that thing do you?
    For those of you who missed it here's Larry's Vicky in Dewey. OK., in May.
    Outback, jet996, drdave and 1 other person like this.
  16. winduptoy
    winduptoy
    ah, yes gotta' go, go, go before I run out of gas....
    with you and @drdave making a sandwich out of me....and a partial root beer, chopped, fat ass
    Outback, jet996 and drdave like this.
  17. Finally fitted the baffles to the roadster sump. Hopefully these will stop me out cornering the oil…
    G Baese, drdave, 4BangerDean and 6 others like this.
  18. winduptoy
    winduptoy
    You won't have to worry about any squeaky hinges
    jet996, drdave, Crazydaddyo and 2 others like this.
  19. jet996
    jet996
    from WY
    Does anyone recognize this regulator? I know I've seen them before but CRAFT has kicked in. It came in a big box o' banger bits I got years ago... image.jpg
    282doorUK and hotrodA like this.
  20. There is a video of this on YouTube
    jet996 likes this.
  21. winduptoy
    winduptoy
    I believe it is an external oil pressure relief valve. I saw one (or something like it) affixed to a Cragar/Miller OHV conversion....is the bolt hole width/pattern the same as the opening in a B block for the fuel pump? Is there an outlet port on the backside?
    I believe it mounts on the fuel pump opening and the inlet is piped from side cover, located on the oil galley. The excess oil is dumped out the backside into the engine....
    My guess...
  22. jet996
    jet996
    from WY
    @winduptoy -Unfortunately I don't have a B block to compare it to. It looks the same. Yes it does have a hole in the center of the flat mounting side. I'll post some more pics tomorrow.
    G Baese, PINEAPPLE and winduptoy like this.
  23. Jiminy
    Jiminy
