July Banger Thread
Discussion in 'The Hokey Ass Message Board' started by Flat Ernie, Jul 1, 2010.
  1. Brendan1959
    Brendan1959
    Mine is noisy on and off load, I suspect the gears were worn to suit the old bearings, the new bearings would, I suspect change the contact area of the teeth perhaps causing the noise.
  2. celticskull
    celticskull
    could it be possible for the selectors to be pushing on the gears ?
    i would have thought if the bearings made 1st and 2nd gears noisy then it would make 3rd gear noisy also
    im no banger expert so im more than likely wrong hahaaa
  3. BCCHOPIT
    BCCHOPIT
  4. jerseyboy
    jerseyboy
  5. TBone69
    TBone69
    from NJ
    Got any more pics or plans for that engine cradle. I plan on pulling the motor and trans soon to rebuild my ch***is.
    Thanks
    TBone
  6. 64gal
    64gal
    Just bought this about 2 months ago. Got it running and took the bumpers and spare tire off. Thats all so far, have a full plate this year. Regards, Tom.
  7. BCCHOPIT
    BCCHOPIT
    It was to HOT and light on cars. Only 650-700 cars. We left early and took a 3 hr drive home - the ice cream brake :D Down town Torrington show is Fri. night 5-9 hope to see ya then
    Bill
  8. Bluto
    Bluto
    I just brought this ........ and I have no questions :)
    The engine is running! That's no joke :D
    And since the little *******s were built over a few months I'm a happy guy.
  9. BCCHOPIT
    BCCHOPIT
    I Have questions Bluto :D
    what is it....
    I think we need more pic when you get time
    thanks Bill
  10. Wildfire
    Wildfire
    Yeah, what is that thing???
  11. Bodger45
    Bodger45
    Anyone ever see one of these before? I got this am at my local swap for 3 bucks. Looks to be NOS. Its 6 volt + ground. I'm going to try it on my banger tomorrow. The bakelite case sure looks nice! TK
  12. Wildfire
    Wildfire
    Worked all day sorting out the turn signals and brake lights, aimed the headlights and set the timing. Also discovered that oil drain plugs tend to work loose! That was a good catch before catastrophic failure.
    Any suggestions on the drain plug? I'm thinking silicone since it will only get an annual change anyway.
    I now have a very well running and somewhat safer car. WOO-HOO (imagine me doing the "happy dance").
  13. Bluto
    Bluto
    Here's another photo to help you guys to ID the ch***is we brought.
    Hint it's for one of Mrs B's collection :cool:
  14. RussTee
    RussTee
    silicone anywhere near your oil is a big no no if it gets into your oil it will clog galleries and begger everything
  15. noboD
    noboD
    Bluto, you're killing us. I'm sure it's something they only made one of, what is it?
  16. Bluto
    Bluto
    Doug you already know.... no fair don't tell
    How could it be one off ch***is if we already got one? OK the body we have is the only one known but there are a few ch***is' out there.
    OIL PLUG! Take out the plug drain the oil into a clean pan. Go to NAPA and get a 'REPAIR' an OVERSIZE PLUG!!
    Put plug in pan ....... Take out again and clean threads with a magnet!
    Put plug in and put old old in if your cheap. Now change your oil every 6 months or you will loose the engine far sooner than you should.....
  17. rockman29
    rockman29
  18. Drain plugs don't "work" loose if tightened properly and proper copper washer/gasket is used. If the threads are worn in the pan then,as Bluto stated, oversize plugs are available from "A" part houses.
  19. Bluto
    Bluto
    You can clean everything ...... put two small washers in a vice and smack'em with a BFH so they bend in the middle ....then JB Weld the washers one to pan and one to the drain plug. From there it's easy to safety wire the drain plug ..... and if you wire it negitive it's easy to find!!
    BUT IF IT's worked loose on its own the threads are shot.... get a repair plug or keep your AAA card close :cool:
  20. kenny g
    kenny g
    I know allyou guys have been kidding about thease ,
    but I just know that ch***y is a real Henweigh.
    I think I had one back in 1937.
  21. Bluto
    Bluto
    By 1937 the 'Henweigh' (joke??)was so old that no one was using it.
    And the ch***is in the photo is earlier than 1937
    Perhaps your thinking of a date you had with some larger farm animal
    Do you own a Nomad?
  22. The same company made Potfers in the 20's
  23. Bluto
    Bluto
    OK Bill Which came first? :)
  24. 97
    97
    The engine is very similar to a Brough Superior 4,:D:D:D but that ch***is and diff don't even look like the donor for the Brough :confused:, it has more than three wheel studs per wheel and the ch***is is different ,mostly at the rear.
    I would guess at American Austin ( Bantam) but I thought they were later than the 20s.
    Maybe a slightly bigger than "7" Austin???
  25. Bluto
    Bluto
    97
    Yeah I noticed that , but we had RHD American cars in New Zealand and also in Canada and Australia back in the 20s and 30s....... also South Africa and Japan and a few other places .:D:D
    The first BMW models (BMW Dixi) were licensed Austin 7s, as were the original American Austins . In France they were made and sold as Rosengarts . In Japan Nissan also used the 7 design as the basis for their cars.
    So Austin motor, and diff, at least ? No? :cool::rolleyes:
    SS? Lotus Mk1 :cool::cool::cool:?
  27. Jonny69
    Jonny69
    from England
    I was thinking Austin as well. The prop / torque tube looks about right but the back suspension isn't right for a 7. Austin Ruby? I've seen that front end on something before as well. Just... can't... quite... put... finger... on... it... :D
    Edit: I reckon I've got it. But I'm going to keep quiet so Bluto can let on :D
  28. RichFox
    RichFox
    I had a '31 American Austin. Long time ago. I don't remember the frame looking like the picture. Might of though. Had a Crager for it when I went in the Army. When I came home the Cragar was gone. Here is how it ended up.
    97
  30. BCCHOPIT
    BCCHOPIT
    Looks like a lot of fun....and you are still here...:D When I was young I only had 4x4 Toyota pick up and I feel lucky to still be here
