Jumping 29 chevy hearse..
Discussion in 'The Hokey Ass Message Board' started by werpknarly, Aug 21, 2013.
  1. werpknarly
    werpknarly
    from wisconsin
    We've a 1929 chevy he****. Stock from the cowling down. . Above 30 mph the front tires would start to alternately hop and head for either/both ditchs... just had it aligned, replaced 1 degree shim w 2 degree. ..
    She no longer dives for the ditch, but the front tires still alternately hop above 30mph
    Any ideas ?
  2. gimpyshotrods
    gimpyshotrods
    Death wobble. Have shock absorbers? Are they working? What is the current caster setting?
  3. Leviman
    Leviman
    Are you wheels/tires balanced?
  4. jkeesey
    jkeesey
    Check the toe. If its toed out the front end will act erratic as you described.
  5. Rusty O'Toole
    Rusty O'Toole
    Drive 29 MPH. What's your hurry. The cemetery will still be there and your p***enger isn't complaining.
  6. If it's stock it should be parallel leaf. Tires out of balance? Out of round? No shocks?
  7. werpknarly
    werpknarly
    from wisconsin
    2 degree castor... "correct toe" per respected shop
  8. Midget25
    Midget25
    If they are hopping that would be balance or shocks. That's if they are not out of round.........
  9. jkeesey
    jkeesey
    I don't like the "correct toe" the correct toe for a 1929 original ch***is is different than that of a new car. Is the shop that serviced it an antique car, hot rod, or modern shop?
  10. werpknarly
    werpknarly
    from wisconsin
    What's correct toe for '29 ?
  11. jkeesey
    jkeesey
    Should be 1/16" but I would run 1/8" so it would track better and tire wear not being a big priority.
  12. gwhite
    gwhite
    SUPER MODERATOR
    2* of caster doesn't sound like much either...I be your steering is really touchy
