Technical ***June 2025 Banger Meet Thread - A Change in the Weather***
Discussion in 'Traditional Hot Rods' started by Jiminy, Jun 2, 2025.
  1. Stovebolt
    Stovebolt
    Screenshot_20250616_173657_Instagram.jpg Screenshot_20250616_173629_Instagram.jpg
    These are from an original Cyclone catalog
    jet996, mvee33, winduptoy and 5 others like this.
  2. Crazydaddyo
    Crazydaddyo
    Mark,
    I've had a couple, but I've never run one. The ones I've had were 7:1 compression ratio with a crowsfoot type chamber. I wouldn't think you would see any difference in performance between the Winfield and the Cyclone. Unless your Winfield does not have a Crowsfoot combustion chamber.
  3. Stovebolt
    Stovebolt
    Thanks for the information and pictures Dan.
    There doesn't seem to be too much difference in the combustion chamber design between the two heads.
    My cast iron 6.8:1 Winfield head is fine.
    Fortunately.
    Crazydaddyo and winduptoy like this.
  4. Crazydaddyo
    Crazydaddyo
    A lot of people believe that you are better off with the cast iron head than an aluminum head.
    winduptoy and Outback like this.
  5. Outback
    Outback
    from NE Vic
    Due to heat distribution? dissimilar metals? Expansion rates?
  6. This one just popped up for sale locally. Weird to see a Gallican actually in a car! IMG_1085.jpeg IMG_1086.jpeg IMG_1087.jpeg
    burl, jet996, Savage Coupe and 9 others like this.
  7. In my opinion there was not enough knowledge in alum casting
    Many of the alum Winfield copied heads did not increase the wall thickness to compensate for the reduction in material strength
    Heads designed with aluminum in mind are very good such as the Brierley
    J
  8. To quote the legendary Ed Winfield:
    "If you want to boil water, aluminum is best. If you want power, iron is best."
  9. Stovebolt
    Stovebolt
    IMG_6673.jpeg Tod has just cast some C.I. Winfield heads
    winduptoy, 4BangerDean and Outback like this.
  10. Stovebolt
    Stovebolt
    head pic.JPG Jim Brierley’s head
    Savage Coupe and winduptoy like this.
  11. Outback
    Outback
    from NE Vic
    This makes the most sense of the reason's I've been given, thanks for the insight John
    I was going to quote this statement...
    I had a 6:1 iron Lion IV on my first banger 20 years ago, it was the only one in stock at the time & I painted it silver to to stir people up :p
    jet996 and winduptoy like this.
  12. Outback
    Outback
    from NE Vic
    They look nice
    winduptoy likes this.
  13. Gary in MN
    Gary in MN
    Ambler - Ford Super Valve in Head brochure. Scan_20250618 (12).png Scan_20250618 (13).png Scan_20250618 (14).png Scan_20250618 (15).png
    burl, jet996, winduptoy and 4 others like this.
  14. s.e.charles
    s.e.charles
    very neat; thanks.
  15. Gary in MN
    Gary in MN
    Ambler poster....better photo. nfs
    burl, jet996, Roadsterguy1930 and 5 others like this.
  16. 4BangerDean
    4BangerDean
    How would I obtain one of these?
  17. GuyW
    GuyW
    Ed was probably correct in his context (the engines, era, general engineering knowledge, etc) but modern aluminum OHV heads allow higher compression ratios without detonation. I note that the flathead bangers were pretty good at boiling water too.
    Outback likes this.
  18. iwanaflattie
    iwanaflattie
    I've been driving the model t pretty often,still running pretty good.
    I haven't change the oil.
    I don't see an aftermarket/remote filter..
    I really have to change the fluids and clean the cooling system.
    Also gotta detail the engine but I've been busy fixing my coe.
    I ordered new plugs and bought oil.
  19. Liking the COE.
    iwanaflattie and winduptoy like this.
  20. 29Sleeper
    29Sleeper
    from SoCal
    Said no one ever..........
    Triple Stromberg 48s for my Rutherford B engine.
  21. 29Sleeper
    29Sleeper
    from SoCal
    The 4E4 Club Lakester will return to Bville this year. Over the years the club has owned several cars, roadsters, lakesters and dragsters. Club members are free to use them to run engines they have built. It ran in May at ElMirage on licensing runs for the guy who will be taking it to Bville. It still has Jim Brierley's turboed Cook in it.
  22. Deeluxe
    Deeluxe
    from island
    Been a while since I stopped by. Always inspired by the radness in these threads! Thanks.
    Recently had a hot and involved weekend with my McLaughlin. Ongoing and multiple water pump failures called for: moderate tear down + component rebuild (re-think.)
    New super stealth waterpump solution apears to be working well. 20250525_150305.jpg 20250527_122536.jpg 20250525_131911.jpg 20250601_155811.jpg
    Lil'Alb, jet996, winduptoy and 6 others like this.
  23. Outback
    Outback
    from NE Vic
    That's an interesting car, what's the engine? Looks to be mid/late teens?
    winduptoy and Deeluxe like this.
  24. Stovebolt
    Stovebolt
    look him up on Facebook “Tod ****ermore” - he’s compiling a list
  25. Outback
    Outback
    from NE Vic
    I ***ume Tod stopped his Banger project when Burtz took off?
  26. Playing around with an idea that I had.. Going to test the thermal capabilities of ABS Plastic, by 3D printing a terminal box and running it! Everything will be custom, down to the external nuts! 2.png 1.png
  27. 110 in my garage, Trying to remove Stock T cam from block. Aftermarket distributor, Gentleman Who built it used a threaded Allen screw to secure the drive gear on the nose of the cam and stripped out the Allen key side. Even after cleaning and soaking it still looks like a split pin. Could get it 80% off And then just stopped. Try to get it off, after an hour, Lost my temper managed to bend the nose of the camshaft, Not my proudest moment. Drilled through from the backside and pushed it out. Went to finish removing the cam and being in such a ****ty mood, Didn’t notice that one of the lifters was still stuck up (After pulling the valves). Bent that. All in all pretty ****py day. Found a nice gentleman with the machine shop here in town that was able to straighten the nose of the cam. He’s also doing the finish machine work on my cross drive back set up, Installing a Vernier coupler for me. Years back I picked up a really nice set of gears from Dan McEachern, But I think I asked him to make them specific for an A cam into a T block Or I lost part, at this point, I just don’t know.
  28. Outback
    Outback
    from NE Vic
    Dang, I'm sure you'll make good of it.
  29. Stovebolt
    Stovebolt
    sorry I cannot help you with that. I'm too new to bangers to be able to tell you.
    Outback likes this.
  30. Outback
    Outback
    from NE Vic
    Todd was on here talking about the process, he was designing a new banger engine. Burtz beat him to the line. Not sure what happened to his project. Someone here will know
