Projects Just A Big Model (T)
Discussion in 'Traditional Hot Rods' started by BigJoeArt, Oct 4, 2022.
  1. BigJoeArt
    BigJoeArt
    Sleep? whats that?
    sounds lame.
    :D:D:D
    Outback, Sancho and drdave like this.
  2. Tim
    Tim
    from KCMO
    At work duh. Lean against that shovel and he’s out
    brEad, Jrs50, BigJoeArt and 3 others like this.
  3. BigJoeArt
    BigJoeArt
    What a week.
    Took a couple days off work while mama and baby girl went on vacation, and got some stuff done around the house, including tearing the roadster up more...
    It was filthy.
    After I cleaned on that for a bit, and fixed a few other things, I got back to the matter at hand.
    I started taking off all the external stuff that I was gonna have to use on the new motor.
    I re-found this cute little guy.
    And I drug the new block over to figure out what I needed to scavenge off the old motor.
    We wound up having to drill and tap a hole for my clutch linkage ball mount, and we started to inventory the parts I had ordered.
    We got the majority of the motor ****oned up friday night, and I taped up the rest after my buddy left, so that I could do "a little touch up work"
    well, I'm helpless.
    The following photos I stole from my Instagram stories at 1:30 Saturday morning when I finally went to bed.
    What I started with...
    what I got to..
    And since it was another undrilled fuel injection block, I was essentially forced to cut the fuel pump boss off.
    I ended the night with a heavy coat of grey primer, getting ready for paint.
    And remember kids! cast iron dust will try and kill you! so wear a respirator and a face shield!
    I did, and I still looked like this by the end of the night.
    Saturday, I decided that since I was gonna have to run the single 2 barrel at least part of the year, that I should probably make it look decent again.
    So I stripped the bubbling paint and texture off it, and did a bunch more grinding. I also loc***ied a bolt into the unused coil bolt boss and cut it off flush.
    It's not perfect, but that's not the point.
    yesterday afternoon we finished getting the stuff all ****oned up, and would have put it in the car, but the high chances for rain kept me from dragging everything outside to install.
    it sure looks good though...
    after I took this picture, I did a slight redesign on the ****py alternator mount I've been fighting all year, and tried to align the pulleys a bit more.
    with any luck it will be in, and running today!
    wish me luck!
    Max Gearhead, brEad, Sancho and 11 others like this.
  4. Tim
    Tim
    from KCMO
    Sounds good man. It getting different exhaust at this point or no?
    winduptoy likes this.
  5. Dan Hay
    Dan Hay
    So, sorry if I missed it. Is that a 350 block since it's a fuel injection unit with the pump boss closed up?
  6. BigJoeArt
    BigJoeArt
    I'm busting to get some miles in before Pete and Jakes open house and then the wheel hub event at speedway.
    The new exhaust will happen when I start work on the top again.
    It is a 350 vortech block. setup for a fatory roller cam (though it has a lumpy lunati roller in it) and it has been bored 30 over to clean up the bores.
  7. AmishMike
    AmishMike
    Hate wires getting greasy, hate factory corrugated covers ( uncleanable). Took old garden hose, stripped off green plastic cover down to black, split length wise, mini tie wraps can wipe dirt right off. I sure liked it.
    brEad, GuyW, Outback and 1 other person like this.
  8. BigJoeArt
    BigJoeArt
    yeah it ****s, but open wires are easy to fix on the road.
    I cut all my zip-ties off, and cleaned the wires up one by one, When I put it back together I'll zip-tie it all back up.
    I actually redid the wiring on my fans and turn signals, so it will be cleaner when I re-install.
    brEad, Sancho and drdave like this.
  9. drdave
    drdave
    The man, the machine, the unstoppable Joey is in the shop and killing it! Nice job!
    brEad, Sancho, winduptoy and 2 others like this.
  10. Tim_with_a_T
    Tim_with_a_T
    That intake, block, and heads cleaned up great. Nice job!
    winduptoy, Outback and BigJoeArt like this.
  11. BigJoeArt
    BigJoeArt
    Thanks guys! I'm just working to get to pete and jakes open house on the 11th!
  12. Tim
    Tim
    from KCMO
    Step one of cleaner wires.
    Install a motor that doesn’t blow oil all over everything.
    Thats it. One step process. You seem to have it under control.
    GuyW, drdave, winduptoy and 4 others like this.
  13. BigJoeArt
    BigJoeArt
    Yeah, that's what I'm hoping. road grime is one thing, but oily mess is another.
    Sancho, winduptoy, Tim and 1 other person like this.
  14. Outback
    Outback
    from NE Vic, Oz
    That's Gold!
    winduptoy, BigJoeArt and guthriesmith like this.
  15. guthriesmith
    guthriesmith
    So…is it back in and running? :D I wish I had your energy…:oops:
    Sancho, Outback, drdave and 2 others like this.
  16. BigJoeArt
    BigJoeArt
    Sorry, no running tonight, we fought for longer than I care to admit to put the motor in, turns out the new crank isn't drilled as deep as my old crank, and the input shaft was bottoming out in the crank.
    frustrating time solved by 2 minutes with a cut off wheel.
    We are delaying the fire up till Wednesday night, I want to ****on some more stuff up.... nicer.
    I'll put up some photos tomorrow.
    Oh' and in case you thought I was slacking, I also put front rotors and pads on my 3/4 ton daily tonight. . .:D:D:D
    Sancho, Outback, High test 63 and 4 others like this.
  17. Tim
    Tim
    from KCMO
    Think you had to slice that once before didn’t you?
    Frustrating how long it can take to put a motor right back where it once was.
    drdave, BigJoeArt and winduptoy like this.
  18. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    Great work, Joey! Be checking your mailbox for something from hot rodding's other Joey.
  19. winduptoy
    winduptoy
    drdave and BigJoeArt like this.
  20. BigJoeArt
    BigJoeArt
    nope, I was actually surprised I didn't have to last time, the old crank was drilled deeper, for whatever reason.
    Oh boy! I love mail!
    Sancho and Tim like this.
  21. BigJoeArt
    BigJoeArt
    No way?! you're making the trip?
    Sancho likes this.
  22. winduptoy
    winduptoy
    Yes way....heading out the 8th or 9th in a banger of course we shall see if it is Roadster weather
    Be there or be square
    brEad, Outback, Tim and 2 others like this.
  23. BigJoeArt
    BigJoeArt
    ok, so pictorial update, as previously stated, I got the motor in last night...
    notice how it has stamped steel covers on it?
    well, I screwed up.
    I stated with the chain from exhaust bolt to exhaust bolt, hanging over the top of the motor, and with towels over my prized 'vette covers...
    then as I was struggling to get the motor in with too long of an input shaft, the chain shifted, and I heard a POP!
    I didn't wanna look.
    big notch, right out of the front p***enger side cover. boy it ****s.
    any ideas on sticking it back together?
    after that happened, I stuck the steel covers on, and finally got the motor in.
    I pulled it back into the shop, stuck my covers back on, and started putting it together again.
    I'm gonna try for a Wednesday fire up.
    I started re-looming my wiring last night.
    I'm trying to consolidate everything I added in after I finished the initial harness and make it cleaner.
    Any weather is Roadster weather if you want it bad enough! :D:D
    brEad, Sancho, Outback and 3 others like this.
  24. Tim
    Tim
    from KCMO
    As much oil as has been soaked into those things I’d say JB weld if staying as cast. Round them off and ignore them if polished
    Outback, pprather and BigJoeArt like this.
  25. Tim_with_a_T
    Tim_with_a_T
    I've seen where people knock down the outer fins, or all the fins and just leave the Corvette script. Might be good candidates to get creative?
    Sancho and BigJoeArt like this.
  26. Tim
    Tim
    from KCMO
    BigJoeArt likes this.
  27. BigJoeArt
    BigJoeArt
    yeah I was gonna try jb weld or something of the sort, but they may wind up modified.
    the only problem is then I loose the killer patina these have.
    You guys would not believe how many old guys about come unglued when I tell them I have no plans to polish the covers.. .
    brEad, Sancho, winduptoy and 4 others like this.
  28. pprather
    pprather
    JB weld. Unpolished.
    winduptoy, drdave, Tim and 1 other person like this.
  29. Tim
    Tim
    from KCMO
    Tape a tongue depressor on either side of the fin and fill the void with a melted purple crayon . Done deal.
    brEad, Bentrodder, Outback and 2 others like this.
  30. Dan Hay
    Dan Hay
    JB Weld will work great, especially since it's cosmetic and carries no load. If you are a JB weld ar-teest like me the seem won't even be noticeable... :)
    Sancho, drdave, winduptoy and 2 others like this.
