Projects Just A Big Model (T)
Discussion in 'Traditional Hot Rods' started by BigJoeArt, Oct 4, 2022.
  1. RodStRace
    RodStRace
    Work at least means funds gathered for the bits and pieces.
    IIRC, the trans comes up and out of the interior. Be careful not to hurt your back or have a slippery floor.
    BigJoeArt, Outback and porkshop like this.
  2. BigJoeArt
    BigJoeArt
    haha I've spent a bunch of money on the next project, which is not this.
    I have pretty much everything to fix my T already, and maybe I can get into some fun stuff.
  3. willymakeit
    willymakeit
    BigJoeArt and Outback like this.
  4. BigJoeArt
    BigJoeArt
    anybody else getting antsy to go on a roadtrip?
    I know I am, and so I knew I had to get my car fixed.
    So I nabbed dads wheel blocks, and found random stuff to fill the center gap so my tires didn't go through them, and then performed the circus that it is to get my car that high off the ground.
    once it was up there I started inspecting the dirty old thing.
    my bellypan/frame/skidplate is working perfect, and you can tell it lives a hard life.
    you can also see the oil from the seeping front pan seal, I'm gonna try and fix that while I'm here too.
    there's a film over everything, and a bunch of tiny pieces of leaves as well.
    I also found that apparently I need to shim my starter a little, and at some point I've removed a tooth of my flywheel.
    luckily I have 167 other teeth to use, so it's fine.
    I also inspected @CoolForSchool58 favorite part, my flat spotted hairpins.
    I spent an hour or more the other night under the car with a rag, just mopping up the oil residue off of things.
    It's nice to put eyes on things after 3 years.
    the next night I had "help"
    while she checked out the inside, I got to work taking the turtledeck off.
    the whole rear end needs cleaned and at least a coat of paint.
    I also started taking things loose to pull the trans, and when I took the Z bar off I had the thought to modify it like I have meant to for a few years.
    I added an inch or so to the top and moved the hole up probably 3/4 of an inch.
    I re***embled it and tried it, and it felt about the same, so I probably need to just fix the pedal, but that's a can of worms I'm not willing to open right now.
    So tomorrow the plan is crank the stove, and swap out the trans/clutch/pressure plate
    If I get that much done I'll be happy.
    I'll report back.
  5. Everyone knows that hairpins on hotrods are a consumable item, like points and brake shoes.
    winduptoy, porkshop, redzula and 2 others like this.
  6. BigJoeArt
    BigJoeArt
    well, I had a somewhat productive day...
    It started slow, cause I spent the morning running places and shuffling children.
    I did, however, while waiting around, have enough time to finish a side project..
    finally got a tag topper.
    and after a bunch of sanding and filing, I was finally able to paint it and polish the face.
    I still have no idea where its going to be mounted.
    PROBLEM FOR ANOTHER DAY.
    time to yank a trans out.
    If you have followed this saga, you know, i've got this down.
    within about a half hour or so, I had the trans out, and was ready to clean some stuff up.
    I yanked out the rubber floormat, and found the evils of the Bonneville rust.
    that, and a couple handfuls of dirt and leaves.
    and there you have it!
    @CoolForSchool58 its ready for pickup!
    so now its just bolt the old trans back together with the shifter and stuff from this one, and clean some stuff and i'm done!
    OOOOOOOORRRRRRRRRR
    How bout we polish the lid?
    I mean I couldn't re-install it with all those part numbers and stuff...
    I did leave one cause it makes me laugh.
    and a few hours and two podcasts later, Polished!
    Now to give the rest of the trans a wash and... WHY DO I HATE MYSELF?
    It had letters, it couldn't have letters.
    and those bumps? ugly.
    This was as far as I got before I had to go do things like more errands, put kids to bed, pretend to sleep, ect. . .
    So, we'll see if I re-***emble the trans tomorrow or if I am REALLY dumb and polish it too.
    I think we all know where this is headed.
    hook00pad, drdave, winduptoy and 7 others like this.
  7. Tim
    Tim
    from KCMO
    I gotta say that stoves chimney looks a little in effective at getting the smoke out of the shop lol
    tear down looks like it’s going well, wash, paint, tear down the road and repeat
    porkshop, Deutscher and BigJoeArt like this.
  8. Outback
    Outback
    from NE Vic, Oz
    what a cool thing it is to be replacing parts that you have worn out! glad it's all going well!
    winduptoy and BigJoeArt like this.
  9. nrgwizard
    nrgwizard
    from Minn. uSA
    Polish, Baby, Polish... ! :D .
    Hi-Reflection quality, so's the spy satellites can see a bic lighter flame-reflection at night. You know they're watching, jealousy n all... :D . You're having Fun, they're, well, not. ;D .
    Besides, "in for a penny, in for a pound", "since I'm this far already, may as well", "etc". :D .
    You know you want to... :D . DOOO it, he whispers...
    Marcus...
  10. BigJoeArt
    BigJoeArt
    Well I got another little stretch of time sunday afternoon, and started sticking the trans together.
    after cleaning some stuff and sealing it up, I decided I should do a little cleanup on the case...
    after just doing some basic cleanup on the driver side, (most of it is hidden by my heel rest anyway)
    I started cleaning the p***enger side....
    and fell and slipped on the polish...
    After a couple more hours of cleaning, sanding, and polishing, I finally called it "done"
    hopefully it wears in nicely.
    and as a finishing touch, I couldn't stand putting the ratio tag back on all rusty and nasty....
    so now it matches too.
    maybe ill start cleaning the car next.
    hook00pad, drdave, Tim and 5 others like this.
  11. willymakeit
    willymakeit
    Did you make the vw tank bigger?
    porkshop likes this.
  12. BigJoeArt
    BigJoeArt
    You know, I planned on it, when I built the framework, and I have room for a drop sump on the driver's side, but I've never gotten around to building it.
    With the car getting 18-22 mpg, I can go around 200 miles on a tank. So I've never really needed the extra reach.
  13. winduptoy
    winduptoy
    yes, since you ask....
    gotta' be soon.....
  14. BigJoeArt
    BigJoeArt
    I started messing with the trans on wednesday night, and when I tried to test fit my input shaft/clutch installation tool, it fell back out.
    Sooo to the kitchen I went.
    after some "persuasion" I got it out.
    that's a problem. (input inserted from rear to show size difference)
    with the new bushing in place (bronze this time) I got the clutch and pressure plate installed.
    with that installed, I could stab in the trans and start ****oning things up.
    I cleaned a bunch of stuff up and repainted a few things, like my footrest. (notice I even polished stainless bolts for it)
    On Saturday night I made the final push to ****on everything up.
    got the tag topper mounted, and some lines to freshen the logo.
    once it was all ready to go I went to bed.
    The next morning I got up and drove it to church....
    and the throwout bearing SCREAMED the whole time.
    so that afternoon I had to pull it all back apart again, and swap it out for another one.
    a little cruise to make sure it was fixed, an I was ready to go.
    In all I swapped (and polished) the trans,
    swapped clutch/pressure plate/ throwout bearing (twice)
    painted the firewall/floor/tunnel/back wall
    polished stainless bolts for multiple things,
    cleaned EVERYTHING,
    lengthened the clutch Z bar input,
    painted the rearend/shock mounts
    adjusted the pinion angle,
    replaced some nuts and bolts,
    built new hard fuel lines for the motor,
    replaced most of the soft fuel line in the car,
    tightened everything,
    and most importantly, tried to put eyes on as much stuff as I could.
    I found a couple things, and now I'm fighting what I think is a fuel issue, but I really need to run the tank out to make sure its not just junk fuel.
    I drove it to work monday, and then around for awhile yesterday, getting used to it again.
    It doesn't ****.
  15. El Hueso
    El Hueso
    It doesn't **** indeed.
    redzula, winduptoy and BigJoeArt like this.
  16. guthriesmith
    guthriesmith
    Yep, doesn't **** at all and I am with you on the road trip deal which I will be doing Friday. :D
    Outback, MMM1693, winduptoy and 2 others like this.
  17. Tim_with_a_T
    Tim_with_a_T
    You’re giving me much needed motivation. Nice job getting it all back together, making some improvements on the way.
    Outback, winduptoy, Tim and 2 others like this.
  18. Tim
    Tim
    from KCMO
    Ready to be beat on again for the summer! Look forward to seeing you down the road.
    BigJoeArt, winduptoy and porkshop like this.
  19. drdave
    drdave
    So did you do the adjustment tweaks and keep the clevises or did you switch to heims?
  20. BigJoeArt
    BigJoeArt
    glad I could inspire a bit. I just have a hard time putting stuff back together dirty.. but it usually snowballs.
    I kept clevises for now, we'll see if anything happens this year.
    Outback, winduptoy, drdave and 4 others like this.
  21. Tim
    Tim
    from KCMO
    Adds extra clevises to tool box stock list…
    rjgideon, drdave, porkshop and 3 others like this.
  22. BigJoeArt
    BigJoeArt
    I got the T out for errands a few times over the weekend
    I even got to do a night drive in it.
    I need to clean my window.
    Sunday evening I had a guy message me about some A arms I was selling, and he asked if I would meet him halfway, and we decided on meeting in Mt Ayr, Iowa.
    But I quickly realized, that to take the roadster, I would need to swap some tires on.
    I've been running around town on the holey tires from Bonneville.
    So at 10:30 I started tearing into it.
    I got the atlas' tires off and swapped on a pair of used firestones I picked up awhile back.
    I've been putting this off for awhile not wanting to do it, and of course, that meant it was the easiest tire swap I've ever done.
    back on the ground by 11:30, with inner trim rings and center caps in place.
    ready to rock.
    The ride up was fairly uneventful, and the handoff was also uneventful.
    this gave me more time to snap a couple pictures in Mt Ayr
    first of my favorite old garage
    and I also snapped a picture with the art installation on the opposing wall
    Then it was time to head back home.
    The whole way up, I was behind people, and never really noticed how hard the motor was spinning, cause I was under the speed limit most of the time.
    Once I was on my way home, I started to really notice how loud it was.
    The above picture is in 5th gear.
    No bueno.
    80 mph is 3000 rpm
    That's not gonna dig it.
    This is a couple problems compounded, I knew I was going to a lesser overdrive with my old trans, but I forgot that since I swapped it, I also swapped to a set of tires that is almost a full inch shorter.
    I also did some math and found that I have a 3.73 rear gear!
    So it looks like I'm gonna find a set of taller gears for the overdrive so I can get the rpm's under control on the highway.
    maybe I'll get it right next time, till then...
    don't the whitewalls look wild?
    Outback, winduptoy, redzula and 8 others like this.
  23. drdave
    drdave
    I tell ya what, there is no way on earth I would be able to get away with running the tires you do and not spend half my life on the side of the road with flats! I have more trouble with flat tires, and I'm running tires within the date stamp AND tread! LOL Killin' it Joey!
    Outback, winduptoy, BigJoeArt and 3 others like this.
  24. Tim
    Tim
    from KCMO
    Not an rpm I’d bat an eye at but I bet with the over drive ratio change and ( likely more influential) dropped tire height it’s a pretty big change. Both in feel, noise and even shift points etc.
    I’m sure you’ll figure out a change that makes you happy. Glad to see ya on the road either way.
    Outback, winduptoy, porkshop and 4 others like this.
  25. Tim
    Tim
    from KCMO
    Looks great with the fat whites too by the way!
    Outback, winduptoy, porkshop and 3 others like this.
  26. guthriesmith
    guthriesmith
    Yep, what Tim said. I wouldn't be concerned with that rpm and also like the wide whites on it.
  27. willymakeit
    willymakeit
  28. BigJoeArt
    BigJoeArt
    oof, guys you know the point of overdrive is to get the revs DOWN right?
    I was running around 2500 at 80 prior to the switch. I knew it would move a little, but didn't want it to move THAT much.
    3k at 80 is a little much for my liking, the motor will run it, but it would probably kill my fuel milage.
    and eventually wear out the motor.
    but I think I can fix it easy enough. . .
    famous last words.
  29. Dave G in Gansevoort
    from Upstate NY
    You need a quick change… I love spending other people’s money!
  30. El Hueso
    El Hueso
    It looks great with the wide whites! Sorry if you mentioned it already, but what size of rear tire are you running now?
