Technical Just a heads up about steering components
Discussion in 'The Hokey Ass Message Board' started by Budget36, May 9, 2024.
  1. Budget36
    Budget36
    I ordered tie rod ends for my daily through Summit. Moog. I did so because Moogs site says “forged steel”
    But I received two cast pieces with a Moog boot.
    Not sure why/how, but they go back tomorrow.
  2. Max Gearhead
    Max Gearhead
    from Wisconsin
  3. Fordors
    Fordors
  4. Budget36
    Budget36
    I can get them in the daylight tomorrow.
    Fordors likes this.
  5. Budget36
    Budget36
    Truckdoctor Andy and Fordors like this.
  6. big duece
    big duece
    from kansas
    Ever bought new sparks plugs only to get home and open up someone else's used ****? Someone probably pulled a switcharoo return and got restocked without being checked. I bought an oil filter at O'Reilly's, once home I opened it and paint was chipped on the outside and oil stain in the bottom of the box. F&#$'n *******s.
    49ratfink and Budget36 like this.
  7. nochop
    nochop
    from norcal
    I’m finding less and less use for summit, jeggs and the likes of speedway
  8. Mike VV
    Mike VV
    from SoCal
    Your not...likely going to find "forged" steering pieces from...anyone, anymore ! A thing of the past.
    I just bought similar parts from a local parts shop for my own car. While yes, they are cast, they ARE good parts. Harder than the average cast iron, and plenty "thick" material.
    You aren't going to break them, without going off a cliff !
    Mike
  9. Budget36
    Budget36
    Here’s what Moog says.
  10. alanp561
    alanp561
    Your new tie rods are cast steel and may well be forged. Take a look at another tie rod also claiming to forged steel. It has the same rough surface as your Moogs and is sold by Summit.
    Truckdoctor Andy and Budget36 like this.
  11. Ziggster
    Ziggster
    Interesting. Googled this topic, and found threads on other forums going all the way back to 2005 questioning the “casting line” vs MOOG’s product statements saying they are forged. I’m no expert, but I would say they look cast as well. Found this on a MOOG Q&A site. MOOG replies they are cast iron (finish)? I would ask them directly. Curious to know as I used some last year on my DD.
    https://www.moog-suspension-parts.com/moog-ds1138t
    Budget36 likes this.
  12. '29 Gizmo
    '29 Gizmo
    from UK
    I think its more important to know if its cast iron or cast steel.
    Budget36, Bentrodder and alanp561 like this.
  13. alchemy
    alchemy
    Huh? Cast, yet forged? How’s that work?
  14. Moog is my 1st choice so what will you find that could be better?
  15. Rickybop
    Rickybop
    Are original tie rod ends in any way rebuildable?
    Could you use the guts of a new one installed in the original forging?
  16. reagen
    reagen
    Work at sifco forge years ago there is no flash trim on the sides of those i don't believe they are forged
    Budget36 and alanp561 like this.
  17. Adriatic Machine
    Adriatic Machine
    I’ve been hearing bad reviews about Moog products over the last few years. Friend of mine kept eating front end parts on his o/t truck until he switched brands.
    Budget36 and seadog like this.
  18. big duece
    big duece
    from kansas
    Curious what a Brinell test would conclude.
    rattlecanrods and Budget36 like this.
  19. Budget36
    Budget36
    That was my thinking as well. Ie **** cranks are cast steel.
    They don’t claim a forging.
  20. Budget36
    Budget36
    Once I get some coffee in me I think calling the direct would be best.
    alanp561, Unkl Ian and RodStRace like this.
  21. Fordors
    Fordors
    The fine line on that tie rod end says casting as others have suggested. There is no information on the Moog 'site about cast or forged being used for tie rod ends but they do tout all the other improvements they have made.
  22. Budget36
    Budget36
    Read above what I posted from Moogs site, was specifically about TREs.
    Fordors likes this.
  23. Budget36
    Budget36
    IMG_0462.png So here’s a zoomed in pic of a Detroit Speed TRE.
    That looks like a forging to my eyes.
    alanp561, Unkl Ian and X-cpe like this.
  24. Adriatic Machine
    Adriatic Machine
    That looks like a nutscape ok I’ll see myself out have a great weekend
    Speccie and Budget36 like this.
  25. Mike VV
    Mike VV
    from SoCal
    Yes sir.
    There's many grades of both iron and steel !
    Some of each are strong, some, not so much.
    Shouldn't whine until you know.
    BUT...yes, advertizing one thing, then giving something different isn't nice .
    Mike
  26. stubbsrodandcustom
    stubbsrodandcustom
    from Spring tx
    Maybe a mis box, maybe it was a standard Moog and was supposed to be the Problem solver line? Who knows.
    Id still run it on anything I owned. Forged vs cast on a part like this would take some serious flying off a cliff to break the cast, I just dont see much benefit here for forged completely tie rod ends.
    lostone and Budget36 like this.
  27. JD Miller
    JD Miller
    Ive thought moog were junk since over 20- 30 years ago when I replaced a chevy 4x4 truck front axle steering knuckle ball joints with moog and they were worn out, loose after only a couple years low mileage driving. They were their supreme $$ super duper heavy duty ones too
    Adriatic Machine and Budget36 like this.
  28. Budget36
    Budget36
    Maybe I’m getting gun shy, but I have visions of tooling down the freeway at 65 MPH and hitting a pothole, one snapping and having a rodeo on my hands.
    These are going back to Summit though. I’ll figure something else out.
  29. 1971BB427
    1971BB427
    from Oregon
    Almost all forged parts begin *** castings. They're rarely forged from bar stock. So the castings are a bit oversized and general shape, then forged to final shape prior to machine work.
    But a forged part will not have the rough sand finish once it's shaped through forging.
    2OLD2FAST and Budget36 like this.
  30. Budget36
    Budget36
    Alan,
    Take a closer look at the parting line, notice the width of the ones you posted, vs the thin line of the one I posted.
    It wasn’t the rough finish that made me do a double look, it was the thin parting line.
    X-cpe and ClayMart like this.
