Technical Just a heads up about steering components
Discussion in 'The Hokey Ass Message Board' started by Budget36, May 9, 2024.
  1. Budget36
    Budget36
    Well, I ordered the AC Delco Gold ones, we’ll see. Only ones in stock and I’d like to get them in before I head back to work.
    But if they come in casted, back they go and I’ll wait for the Detroit speed ones.
  2. chickenridgerods
    chickenridgerods
    from DSM, IA
    I suppose if you consider the ingots from which forged parts are made to be the "cast" form of the part.
    Something such as a tie rod end or steering arm isn't going to be "pre-cast" in an oversized state and then forged to final shape.
    Unkl Ian and Budget36 like this.
  3. Zax
    Zax
    ****er
    Budget36 likes this.
  4. rattlecanrods
    rattlecanrods
    Something doesn't make sense on Moogs material. 16MnCr5 is not equivalent to SAE 1040. The former is a low carbon steel and the latter is high carbon steel. Not at all alike.
    16MnCr5 is more like SAE 5115 steel.
    Screenshot_20240510_195117_Brave.jpg I believe you made the right choice tossing then back...
  5. seb fontana
    seb fontana
    from ct
    Smoke and mirrors.
    rattlecanrods and Budget36 like this.
  6. gene-koning
    gene-koning
    I too quite buying Moog parts about 15 - 20 years ago. They have not been a high quality manufacturer for a long time. They certainly are not worth a premium price.
    The weak point on a tie rod end is not the formed steel/cast part, its the ball end. I have seen cheap tie rods ends bent to nearly 90 degrees without the steel/cast end itself failing. The ball end is a different story. I've even had one that broke the stud off just below the nut.
    Truckdoctor Andy and Budget36 like this.
  7. Unfortunately, Moog is just a name on a box today. What you receive inside is a **** shoot. If Moog was still US made, I’d happily pay the difference.
    alanp561 and Budget36 like this.
  8. Unkl Ian
    Unkl Ian
    IIRC, Magnum had a problem with their axles. There were several failures, after only a few miles,
    that were well do***ented online. Including one broken leg. Most likely, wrong material was used
    in casting. And now, Magnum is gone. Super Bell has had a few of their spindles break.
    Can you run cast suspension parts, safely ? Yes, for sure.
    But they need to be made of the correct material, and designed accordingly.
  9. nochop
    nochop
    from norcal
    I think everyone would know if moog components had issues. Lots of lawyers
  10. Budget36
    Budget36
    True. But saying forged and being cast isn’t a good thing. Had there been no mentioned of “quality forged steel **x” I’d had not even given it a thought.
  11. Wrench97
    Wrench97
    Current Moog parts are just as junky as the rest of the off shore parts sold today.
    RMR&C and Budget36 like this.
