Technical Just a little help
Discussion in 'The Hokey Ass Message Board' started by Merc40, May 20, 2015.
  1. Merc40
    Merc40
    I have a 1940 mercury. It keeps blowing out my 30amp fuse( power seats and windows.). Just started doing this. Each time I change the fuse it works for a few seconds then blows out. Any ideas why it doing this?
  2. Bam.inc
    Bam.inc
    from KS
    Not familiar with the '40 Mercury power seats or power window options?
    But maybe someone on the internet can help you.
  3. Bam.inc
    Bam.inc
    from KS
    Ok. That's a smart-*** answer. The car in your avatar looks cool.
    But I'm not sure many HAMB threads will get very technical on, or admit power seats or power windows. Hope you get it figured out, maybe someone will pm you.
  4. tommyd
    tommyd
    from South Indy
    Maybe you have a bare wire under the seat or in the door. When you move the seat or roll down the window it shorts and pops the fuse?
  5. 30tudor
    30tudor
    If it blows the fuse to the power seats and windows you know where to look for the problem. My first thought would be to look for a bare wire at or near the door jamb
  6. brady1929
    brady1929
    Yes you have a short somewhere. Start checking the wiring. What color is your Merc? Very nice.
  7. COCONUTS
    COCONUTS
    Maybe your **** is to heavy, ha ha--only joking. I would disconnect one or the other to isolate the problem, is it the window or the seat, that would be the question, or it could be the main power going in, before going off to the two separate components. Whatever you do, don't wrap the fuse in tin foil.
    Bam.inc likes this.
  8. Jalopy Joker
    Jalopy Joker
    are there any relays in the system? really would help prevent overloads
  9. Merc40
    Merc40
    Black
  10. Merc40
    Merc40
    Thanks for the help.
  11. fordor41
    fordor41
    If no shorted wiring found maybe the motors are getting tired or mechanisms are dirty, binding. Put a DC amp meter on the power leads to each and see what the draw is. Maybe just enough over the fuse rating to blow them
    Hnstray likes this.
  12. 55 dude
    55 dude
    unplug both circuts and connect one at a time, your prolem will show itself quickly!
