Technical Just a question for the masses. How to remove an oil fill tube
Discussion in 'The Hokey Ass Message Board' started by porknbeaner, May 8, 2023.
  1. ClayMart
    ClayMart
    I've also heard of using this method to free up a seized distributor that's stuck in the block. Not tried it myself but it sounds plausible and might keep you from busting up the distributor housing with a hammer or slide-bar puller.
    Stogy likes this.
  2. Dennis D
    Dennis D
    Blind hole brg. puller?
    Stogy likes this.
  3. manyolcars
    manyolcars
    I love 40 Fords. Show us pictures please
    Stogy likes this.
  4. Ebbsspeed
    Ebbsspeed
    Drill a hole cross-wise through the top of the tube. Hook your slide hammer onto the bolt and tap it out. The cap covers the top of the tube anyway so a hole through the top doesn't affect anything, except it might drool a bit if you're not careful adding oil.
  5. Johnny Gee
    Johnny Gee
    from Downey, Ca
    ^^^^^ My luck would be like the screw driver thru the oil filter trick. Filter all torn up and still refuses to move.
    Stogy likes this.
  6. I thought of another one, but it involves taking the intake off. A tapered wooden dowel inside the tube, from the underside (but the taper would have to grab the tube above the intake).
