Technical just a question
Discussion in 'Traditional Hot Rods' started by V4F, Aug 11, 2015.
  1. V4F
    V4F
    from middle ca.
    on a flathead V8 ............ what does "59 a-b" mean ? ........... thanks .. steve
  2. Dooley
    Dooley
    from Buffalo NY
    Model T1 and dana barlow like this.
  3. V4F
    V4F
    from middle ca.
    thanks ... so I should have the 90-100 hp motor !
  4. Gene Boul
    Gene Boul
    A lready B cracked! These were replacement motors installed after the war. I was told by elderly gent that since car production was behind from the war effort Henry would replace your worn-out flattie with a new AB short block (minimum) + what ever else was needed for 80.00. Ford used whatever you had that was good and added the AB to it. Told it was done in one day! Merc's got the same AB, i.e, no Merc AB's.
  5. V4F
    V4F
    from middle ca.
