Just another Flathead V8
Discussion in 'The Hokey Ass Message Board' started by Elco Heads, Jan 14, 2013.
  1. Elco Heads
    Elco Heads
    Hi from downunder. My 1940 Flathead V8 has finally arrived here in Australia. It is fitted with Elco twin plug heads and a Nash twin 8 distributor mounted on a right angle drive. I have also collected a few NOS parts for this distributor which are very hard to find. This engine is going into my 1930 A coupe in the near future.
  2. Retroline
    Retroline
    Well that should bring it to life.. Nice coupe as well, what internals?
  3. lothiandon1940
    lothiandon1940
    That Flathead is a beautiful piece and your Model A is equally as nice.
  4. Doctor Detroit
    Doctor Detroit
    That's a good looking Flathead....
  5. 50flathead
    50flathead
    from Iowa, USA
    That flathead is bad ***!!!!
  6. 52ragtop
    52ragtop
    from Nebraska
    They don't get much sweeter than that.. Anxious to see it together.
  7. flathead4d
    flathead4d
    Bore, stroke, cam, etc? What trans will you use?
  8. Blake84
    Blake84
    REALLY!!!!! REALLLLY!!! YOU LUCKY SON OF A ........GUN !!! i would love to drop that in my 50 ford......GOODLUCK with it....its gorgeous. drive the hell out of it....
  9. FiddyFour
    FiddyFour
    i would never hide that motor under a hood or behind fenders... twin plug heads are pure ****
  10. What Fiddy said!
  11. Derek Mitchell
    Derek Mitchell
    That is pure *** right there. Absolutly gorgeous.
  12. Elco Heads
    Elco Heads
    Hi The engine is stock at present. I am presently working on what internals i will be running in the engine. Thanks Terry
  13. 19Fordy
    19Fordy
    Beautiful. Please explain the advantage of twin fire heads and how do the plugs actually fire into the cylinder. How is the cylinder head combustion chamber configuration different than the block? Just curious.
  14. banjorear
    banjorear
    Beautiful looking engine. Super cool. Curious on your choice to run those double pulley truck water pumps?
  15. roseville carl
    roseville carl
    Very very very nice..........
  16. e-tek
    e-tek
    from SK, Canada
    Having never even seen double-fire heads before, I wonder what advantages do they confer - other than the obvious advantage of making you the coolest mo-fo in flatthead land! ;)
  17. VoodooTwin
    VoodooTwin
    from Noo Yawk
    That **** right there is traditional hotrod ****.
  18. 40FordGuy
    40FordGuy
    Bad-*** *****in' ! ! ! Please keep us posted....
    4TTRUK
  19. QQMOON
    QQMOON
    Weak at the knees ........................... Good stuff
    QQ
  20. There was a roadster that I saw last june with a setup like this on it.
    Here are a couple photo's,
  21. model.A.keith
    model.A.keith
    VERY Nice...........
    whats the spec on the motor.....??
    K
  22. fenderless
    fenderless
    from Norway
    AAHHHH!!!! JUST PLAIN ***Y AAAAHHHH!
    Taildragger&fenderless
  23. HOTFR8
    HOTFR8
    WOW. OMG. WOW. If I had that I would always have an open engine bay.
