Projects just Another Model A Build
Discussion in 'The Hokey Ass Message Board' started by dmdeaton, Jan 27, 2018.
  1. dmdeaton
    dmdeaton
    Another goofy question, what do you use to tighten lug nuts on these rims? Short socket with universal barely makes it.
  2. dmdeaton
    dmdeaton
    Working on ******, battery box, and master cylinder.
    Wife cleaned up the body tonight.
    tb33anda3rd, Dannerr, brEad and 3 others like this.
  3. Marcia
    Marcia
  4. Marcia
    Marcia
    I'm building one, too.[​IMG]
    Sent from my XT1650 using The H.A.M.B. mobile app
  5. dmdeaton
    dmdeaton
    I didn't try a simple lug wrench. Glad to see more building going on. My first and don't know what the hell I'm doing.:eek:
    Dannerr and Marcia like this.
  6. dmdeaton
    dmdeaton
    Do you guys think I should weld box tubing behind the center crossmember that I almost notched in half? I feel I should do something there.
  7. Marcia
    Marcia
    Post a picture, how bad is it?
  8. fourspd2quad
    fourspd2quad
    Dan,
    You took a nice chunk out of that cross member. I would definitely stiffen that back up. While you are at it now would be a perfect time to add some boxing to the frame rails. I know you are running a banger but those frames were originally designed to flex anyhow. Just a thought.
  9. waxhead
    waxhead
    from West Oz
    Not sure how I missed this thread before, but watching now.
  10. fourspd2quad
    fourspd2quad
    Maybe the topic didn't grab you?
  11. dmdeaton
    dmdeaton
    Yes, those are my thoughts also. In the pics I have mocked up using the flex motor mounts. I am thinking of going back to the solid originals. The solids have to stiffen it up some also. Puts strain on the flywheel housing though. Lots of them are cracked.
  12. dmdeaton
    dmdeaton
    osage orange and OFT like this.
  13. dmdeaton
    dmdeaton
    I ordered a set of the boxing pieces. I figured for $150 it will help. I wont use all but it will be worth it. I figure it should give me good easy welding practice. :eek:
  14. dmdeaton
    dmdeaton
  15. dmdeaton
    dmdeaton
  16. fourspd2quad
    fourspd2quad
    Dan,
    You are doing a killer job there. Very nice work, love the headers too.
  17. 97
    97
    You mentioned that a lot of bell housings/flywheel housings are cracked. One reason is because people do not use the correct gasket and shims behind the upper housing to the block . They crack when the bolts are tightened , because the gorilla on the spanner tries to close up the gap. Or if the gap is not shimmed they break when you go over a large bump.
    You need to make a dial indicator off the crank to make sure the face of the flywheel housing is square and true to the crank, and again when the flywheel is installed.
    more info
    http://forums.aaca.org/topic/224545-model-a-flywheel-housing-to-block/
    http://www.ocmafc.com/techarticles/Clutch Housing Alignment.pdf
    barrnone50, Dannerr and dmdeaton like this.
  18. dmdeaton
    dmdeaton
  19. dmdeaton
    dmdeaton
    body on frame finally!!
    Dannerr and brEad like this.
  20. winduptoy
    winduptoy
    There has been some banging going on in your shop
  21. dmdeaton
    dmdeaton
    Nice head, winduptoy!
    winduptoy likes this.
  22. nailheadroadster
    nailheadroadster
    Looks like great progress dmdeaton! The body cleaned up very nicely!
    Did you build the engine or have it done? What are the specs on it?
    Also, could you post the info for the gentleman in KY you mentioned doing the T5 plates & conversion, please?
  23. 392
    392
    Nice and clean build.
  24. dmdeaton
    dmdeaton
    Thanks guys,
    The engine is a old rebuilt beater I bought from a hot rod part out. It ran when I bought it, brought it home and dis***embled it for inspection. Bored 60 and clean inside. Changed all gaskets, Stipes 340 cam, added modern valve set with new springs. Jim Brierley head, Scalded Dog intake, and a Stromberg 97. This is my first A engine to play with. I have a B block at the machine shop having all the goodies done to it. If this thing runs good, I may have to find another project for next winter to put it in.
    kidcampbell71 and brEad like this.
  25. dmdeaton
    dmdeaton
    John Baker
    606-348-8533
    Monticello, KY
    He is not a hot rod guy, but he knows transmissions. Has a trans shop for his real life. Not too much a computer guy either. He sets up his tables at mostly Model A club meets.
    kidcampbell71 and Dannerr like this.
  26. dmdeaton
    dmdeaton
    Fuel tank install was a *****. Imho the worse task so far on the build. A little sloppy in the right corner, but turned out decent. Now I can get a lot done around the tank that I have been waiting to do. And......maybe start this beast up!
  27. clunker
    clunker
    from Boston MA
    Thanks for the thread, looks great. Very informative and inspiring, I would like to build an A Fordor as well. I am just learning about A’s. I find it hard to grasp something unless it is sitting right there in front of me, so these threads are helping.
    (I have the same Rikon band saw and recognize all of the Jet, Powermatic, Oneida, Dewault equipment in the background. I am a furniture maker by trade. If you were also able to finish your boat in the past few months as well, that would be incredible)
  28. dmdeaton
    dmdeaton
    I Haven't posted in a while, so here is a quick update. I am knee deep in the wiring and almost ready to fire the engine up. Picked out color for seats today and it is going to Mikey Brown's place in a few weeks to get the interior done. He is in Indiana and does a bang up job. I can see light at the end of the tunnel!!
  29. fourspd2quad
    fourspd2quad
    Coming along nicely Dan. The engine looks great. Nice finned crank cover BTW ;)
  30. Binger
    Binger
    from wyoming
    Looks great! It is always nice to have the end of a project in sight!!
