just another shoebox budget build
Discussion in 'The Hokey Ass Message Board' started by tedley, Oct 24, 2010.
  1. Buddy Palumbo
    Buddy Palumbo
    The scoops look great
  2. tedley
    tedley
    from canada
    Thanks for your interests guys.
    After a lot of farting around i finally got the scoop to fit like the other side. Doing right and left of anything ****. Very time consuming. I'm actually ready to bodywork the skirts.
    I look around the garage and man i'm a pig when i'm working. I just don't really notice the mess as i'm a little to focused on what i'm doing and not aware of the mess. Anyone else have that disease?
  3. Finnrodder
    Finnrodder
    from Finland
    Hey,that mess looks really familiar.Its exactly same thing with me.
    And nice work with the skirts!
  4. jerseymike
    jerseymike
    skirts look good! and was the jets game on while all this work was getting done?
  5. tedley
    tedley
    from canada
    Thanks guys.
    No it was done 1 hr before hand. Game was a stinker:(
  6. F91
    F91
    Awesome build. Subscribed
  7. tedley
    tedley
    from canada
    Thanks.
    -40 today...i'm hiding in the house.:mad:
  8. Buddy Palumbo
    Buddy Palumbo
    Eff that noise , dude ... that's waaaayyy too friggin' cold !!!!!!!! I'd move south ;) .
  9. David562
    David562
    from usa
    Awesome...looking forward to watching your build...post lots of pics as I am doing a shoebox with 302 and undecided on trans but thinking AOD[​IMG][​IMG][​IMG][​IMG][​IMG]
  10. tedley
    tedley
    from canada
    Your pics didn't show but hey..if you can pick up a hint or two, that's great.
    Thanks for the interest.
  11. Mr.Dickies
    Mr.Dickies
  12. tedley
    tedley
    from canada
    Thanks for the heads up on those mirrors. They are the ticket. I just don't know where i'm going to get the scratch thou. I know i could get a good buck for mine as i've seen them go for over 3 hun used and mine are nos. So it would be a gamble. I've got a few days of pondering but will keep an eye on them.
    Thanks man.
  13. tedley
    tedley
    from canada
    Did some bondo work this week and got some hi build on the skirts. Looks so much better. Just have to fine tune those scoops.
  14. jerseymike
    jerseymike
    skirts look great! i liked them before but now in primer they really flow with the car. like most things hand made, definitely worth the extra work!
  15. Nice work on the scoops! They look great.
  16. EBW
    EBW
    Damn, those are ***y !!
  17. tedley
    tedley
    from canada
    Thanks guys. Sometimes s**** comes in handy to make stuff.
  18. leadsled deluxe
    leadsled deluxe
    Coming together good nice scoops.
  19. tedley
    tedley
    from canada
    I need an opinion on driveshaft clearance. I'm using 3 in lowering blocks which is common i think but i thing my springs are sagged out. I don't wont to raise the car and i only had 1/2 in clearance. So cut the floor and going to make a short tunnel. I'm think i have enough clearance now but not 100 % sure. Anybody confirm from their build experiance?
    I have 1 in at the front which is not far from the frt pivot of the shaft and a bit better than 2 at the frt seat hump which is level with the x member underneath.
    Good to go?
  20. daddio211
    daddio211
    I don't have the answer but I'm grateful you're detailing and investigating this. I'll be doing the same soon!
    Sent from my DROID device using the TJJ mobile app
  21. el diablo
    el diablo
    from Norco CA
    I would imagine it would depend on your travel in the rear. I think you would need to have full movement without the driveline hitting anything.
  22. tedley
    tedley
    from canada
    Well, like i said, i'm maxed out at the rear hump as the xmember is under there and can't go any higher without cutting it to. I was hoping someone has a measurement from their build. I 'm sure i'm ok at the frt as there is not much movement at that point. I really don't want to raise the rear as it looks natural right now with the skirts. 2 1/4 at the rear hump is enough i think considering it's about 1/2 way done the shaft and travel through the arch travel is not that much at that point compared to the end at the rear end.
  23. EBW
    EBW
    I also don't have the answer.. But if no one chimes in.. I would error on caution and add a 1/4"- 1/2" just to be safe... ?
    Hopefully someone chimes in as I ALSO will be doing this very soon.
  24. el diablo
    el diablo
    from Norco CA
    I stepped the rear brace for clearance but I have bags in the rear. Put some weight in the trunk and see what kind of travel you have before it hits. You could also make some bump stops if your worried about it hitting and don't want to clearance the rear brace.
  25. tedley
    tedley
    from canada
    Well i spent a few hours making a tunnel, nothing fancy. I went 1/2 higher than the x member. I think i'll be ok or i'll have to go up. Done deal.
  26. EBW
    EBW
    NICE !! That looks clean and subtle.. almost stock !
  27. el diablo
    el diablo
    from Norco CA
    Looks good man!
  28. F91
    F91
    Cool stuff. Keep it coming.
  29. Buddy Palumbo
    Buddy Palumbo
    nice fix - it looks original
  30. tedley
    tedley
    from canada
    Thanks everyone.
    Omg, i was looking around last night and i think that's the last item i have to fabricate. I'm inching away to completion here:)
