just chopped my 49 ford
Discussion in 'The Hokey Ass Message Board' started by ChicagoSlackers1, Jul 15, 2008.
  1. ChicagoSlackers1
    ChicagoSlackers1
  2. Gerg
    Gerg
    looks like it's well on it's way!
  3. Kustom7777
    Kustom7777
    from Austin, TX
    looks good
    how much did you take out?
  4. skyrodder
    skyrodder
    looks good dood
  5. ironandsteele
    ironandsteele
    very cool. what color is it going to end up being? chop looks good.
  6. Bad Bob
    Bad Bob
    from O.C. Baby
    Looks like it was too easy,LOL!!! Nice job!
  7. Moparhead
    Moparhead
    Nice job!
    Fuzz
  8. SlowandLow63
    SlowandLow63
    from Central NJ
    Definitely looks good. Looks like you used alot of the C-pillar rather than making a new piece. How'd that work out?
  9. lostn51
    lostn51
    from Tennessee
    I did the same thing when i cut my 49 and it was too easy using the left over piece than to make a new one up. i really dig the chop, cant wait to see more pics of it as you get more of it done!!!!
  10. SlowandLow63
    SlowandLow63
    from Central NJ
    I had wondered why most used a new piece instead. I thought maybe the shape was that far off that a new piece was easier and better. Looks like not so much. Cool.
  11. Nitrofan
    Nitrofan
    from Kentucky
    Nice Job, looks great!
  12. merc-o-madness
    merc-o-madness
    sweet! looks good. mine is coming along very similar but mine is less chopped i think
  13. ChicagoSlackers1
    ChicagoSlackers1
    We took out 4 1/2/ in front and around 6 in the rear
  14. UnIOnViLLEHauNT
    UnIOnViLLEHauNT
    Because the more you cut out the less the metal will line up. It will look like two contoured pieces with a serious valley in the middle if it meets at all. On a more mild chop you can try to use a lot of stock metal with small patches. On my Merc which was not radical, it would have been a disaster as the crown is way different, nothing would have lined up.
  15. UnIOnViLLEHauNT
    UnIOnViLLEHauNT
    Looks really well thought out and will have a killer profile. Did you move the straight pillar back or are you leaning them? How did that roof cut at the a pillar work out? Looks like less of a valley than when people make the \ / cuts in either end. Very cool!
  16. whid
    whid
    nice........dave
  17. Mudslinger
    Mudslinger
    You hit that one just right! Nice...............
  18. ChicagoSlackers1
    ChicagoSlackers1
    that worked out good because we moved the back window forward about 4 1/2 inches we only had to put like a 3" wide triangle in there and in the end it really only needed a scim coat of mud.
  19. FyUoCuK239
    FyUoCuK239
    looks really good...thats all i got to say about that.
  20. Roadsters.com
    Roadsters.com
  21. PunkAssGearhead88
    PunkAssGearhead88
    from So Cal
    Nice, I like those proportions. I like how a sedan looks chopped when the rear window is moved forward, it makes it look more like a coupe.
  22. SICBOY
    SICBOY
  23. invizibletouch
    invizibletouch
    from Mobile, AL
    Looks real good man. Gonna do my 49' as soon as I finish welding all my patch panels in. Do you have any more pics?
  24. ChicagoSlackers1
    ChicagoSlackers1
  25. ChicagoSlackers1
    ChicagoSlackers1
    I cant get all my pics on here but I have a bunch on our web sight www.slackerscc.com under project cars and will have more posted soon
  26. SlowandLow63
    SlowandLow63
    from Central NJ
    Really? That much? I see the 4 1/2 in the front but it looks like less in the rear. Where did you measure from? Or was it cut til it looks right?
  27. 00 MACK
    00 MACK
    Cant get enough!This thing has that Frank Palmer look!
  28. ChicagoSlackers1
    ChicagoSlackers1
    Basically it was originally cut at 5 1/2 in the rear but was moved around till it looked right and I guesstimate 6" in the c pillar.
    <?xml:namespace prefix = v ns = "urn:schemas-microsoft-com:vml" /><v:shapetype id=_x0000_t75 stroked="f" filled="f" path="m@4@5l@4@11@9@11@9@5xe" o:preferrelative="t" o:spt="75" coordsize="21600,21600"><v:stroke joinstyle="miter"></v:stroke><v:formulas><v:f eqn="if lineDrawn pixelLineWidth 0"></v:f><v:f eqn="sum @0 1 0"></v:f><v:f eqn="sum 0 0 @1"></v:f><v:f eqn="prod @2 1 2"></v:f><v:f eqn="prod @3 21600 pixelWidth"></v:f><v:f eqn="prod @3 21600 pixelHeight"></v:f><v:f eqn="sum @0 0 1"></v:f><v:f eqn="prod @6 1 2"></v:f><v:f eqn="prod @7 21600 pixelWidth"></v:f><v:f eqn="sum @8 21600 0"></v:f><v:f eqn="prod @7 21600 pixelHeight"></v:f><v:f eqn="sum @10 21600 0"></v:f></v:formulas><v:path o:connecttype="rect" gradientshapeok="t" o:extrusionok="f"></v:path><?xml:namespace prefix = o ns = "urn:schemas-microsoft-com:eek:ffice:eek:ffice" /><o:lock aspectratio="t" v:ext="edit"><v:shapetype id=_x0000_t75 stroked="f" filled="f" path="m@4@5l@4@11@9@11@9@5xe" o:preferrelative="t" o:spt="75" coordsize="21600,21600"><v:stroke joinstyle="miter"></v:stroke><v:formulas><v:f eqn="if lineDrawn pixelLineWidth 0"></v:f><v:f eqn="sum @0 1 0"></v:f><v:f eqn="sum 0 0 @1"></v:f><v:f eqn="prod @2 1 2"></v:f><v:f eqn="prod @3 21600 pixelWidth"></v:f><v:f eqn="prod @3 21600 pixelHeight"></v:f><v:f eqn="sum @0 0 1"></v:f><v:f eqn="prod @6 1 2"></v:f><v:f eqn="prod @7 21600 pixelWidth"></v:f><v:f eqn="sum @8 21600 0"></v:f><v:f eqn="prod @7 21600 pixelHeight"></v:f><v:f eqn="sum @10 21600 0"></v:f></v:formulas><v:path o:connecttype="rect" gradientshapeok="t" o:extrusionok="f"></v:path><o:lock aspectratio="t" v:ext="edit"></o:lock></v:shapetype>
  29. ChicagoSlackers1
    ChicagoSlackers1
    Heres some more pics
    [​IMG] [​IMG]
    [​IMG] [​IMG]
    [​IMG] [​IMG]
    [​IMG] [​IMG]
    [​IMG] [​IMG]
  30. ChicagoSlackers1
    ChicagoSlackers1
    some pics of day one
    [​IMG] [​IMG]
    [​IMG] [​IMG]
    A pic of the top in bondo befor we shaved off about 80% of it[​IMG] [​IMG]
