Technical Just curious about a Dart 5.2 block
Discussion in 'The Hokey Ass Message Board' started by Budget36, May 19, 2023.
  1. Budget36
    Budget36
    I’m not in the market at all for a small block 427, etc. but a buddy sent me a link earlier today about a “Dart 5.2 427” engine.
    Googling yielded no results, Darts site had nothing I could find.
    What the heck is the “5.2” referencing?
    I’m thinking a version of the block?
  2. King ford
    King ford
    from 08302
    "5.2" may possibly be deck height
  3. Budget36
    Budget36
    Hmnn, SBC is 9.025? Maybe dart looks at a different measurement?
  4. nosford
    nosford
    Bore centers?
  5. Budget36
    Budget36
    I’ve not a clue! Lol. Wait, @DDDenny has a small block 427, but don’t know if it’s a Dart block?
  6. DDDenny
    Rodeck.
    Budget36 likes this.
  7. Budget36
    Budget36
    Well dang, you’re no help;).
    I may wear out Google tonight.
    Thanks for that!
  8. DDDenny
    Reminds me of what June Cleaver said....."you were a little rough on the beaver Ward".:eek:
  9. Budget36
    Budget36
  10. partsdawg
    partsdawg
    from Minnesota
  11. Budget36
    Budget36
  12. nosford
    nosford
  13. Budget36
    Budget36
  14. Ericnova72
    Ericnova72
    from Michigan
    It's just Skip White's designation for this particular build combination. He has several levels of performance engines, changing cams, compression ratio's, heads, or strength of rotating ***embly parts.
    The "5.2" is not any number ***ociated or ***igned by Dart, and doesn't refer to any dimension on the block.
    The link you were sent just happens to be "Version 5.2"
    For example....
    Here's a Dart block destroker, 377 cubes, "Version 2.3"
    CHEVY TURN KEY SBC 377 STAGE 2.3 DART BLOCK, CRATE MOTOR 530 hp | Skip White Performance - We have the best prices you will ever find for aluminum heads, rotating ***emblies and strokers
    434", now "Version 5.5"
    CHEVY TURN KEY 434 STAGE 5.5 DART BLOCK AFR HEADS CRATE MOTOR 632hp-SERPENTINE K1 | Skip White Performance - We have the best prices you will ever find for aluminum heads, rotating ***emblies and strokers
  15. nosford
    nosford
    Well okay, I guess that explains it. Thanks ericnova72. I was curious too.
  16. jimmy six
    jimmy six
    We’ve been running a Dart sportsman block in our circle track car for years. Started as a 377” and now a 422”. I would not build a racing engine without one of the aftermarket blocks and maybe not a street engine either. The bore can be 4.185” and a 4” crank (you figure it out) will fit eventho we use a 3-7/8”. The best this is EVERYTHING is off the shelf. **** and CP/Carillo have everything covered. Today any style cylinder head you can think of is offered and so are sportsman shaft rocker arms…..
  17. Budget36
    Budget36
    Thanks for that . I will be able to sleep better now. Lol.
