just getting started '56 Ford Mainline
Discussion in 'The Hokey Ass Message Board' started by fullsizejohn, Jan 14, 2013.
  1. 34toddster
    34toddster
    from Missouri
    Are your fenders rusted out around the headlights, I need a patch panel for that area both sides. Talked to EMS nothing in the works from them. I wonder if 55 and 56 are the same?
    Your Ford is looking good Keep up the good work!
  2. HOTRODPRIMER
    HOTRODPRIMER
    I wish EMS had been making these when I had to replace my lower panels on the wagon,,it would have saved us a lot of time fabricating them from scratch.
    Nice work on your part. HRP
  3. JoeyP.
    JoeyP.
    Cool car, looks like you are making good progress, keep it up.
  4. ems customer service
    great work!
    the ems guy
  5. Squablow
    Squablow
    If your jambs are solid, then there's no need to cut them out, the way you did yours is the way I typically do mine, unless it's rotted into the jamb, then there's not really a choice. Looks like you're doing good work, keep it up.
  6. sb55main
    sb55main
    What did you use for the cross member?
  7. fullsizejohn
    fullsizejohn
    The crossmember was made out of some 10 gauge sheet steel. The worst part was the reverse engineering from a pile of rust!
  8. Hunter73
    Hunter73
    Nice work so far! I'm subscribing to keep up with your progress.
  9. fullsizejohn
    fullsizejohn
  10. charleyw
    charleyw
  11. fullsizejohn
    fullsizejohn
  12. fullsizejohn
    fullsizejohn
  13. fullsizejohn
    fullsizejohn
  14. fullsizejohn
    fullsizejohn
  15. fullsizejohn
    fullsizejohn
