Technical Just how much compression can a 6 volt system handle starting
Discussion in 'The Hokey Ass Message Board' started by junkyardjeff, Apr 10, 2021.
  1. junkyardjeff
    junkyardjeff
    I had the idea of staying with 6 volts on a future project that will most likely be around a Y block so just how much more compression over stock can a 6 volt system take,if its not much then I think I might just forget that idea of staying with 6 volts as I do not want to have problems starting mainly when at operating temps.
  2. TCATTC
    TCATTC
    Bite the bullet and do a 12v conversion to start with.
  3. Its is not the volts that crank the motor, its the amps. If you have appropriate cranking amps and a starter stout enough to spin the motor then you can start anything with a 6V battery that you can a 12V battery.
    On a street driven vehicle with iron heads you are not going much past 10:1, your 6V system in good shape should handle that just fine.
  4. junkyardjeff
    junkyardjeff
    I remember reading when you get a flathead around the 9s they had a hard time starting.
  5. Joe Travers
    Joe Travers
    from Louisiana
    Look for a 6V battery and starter that will provide higher CCA. There should be a combination that beats stock specs. If not, go 12V.
  6. flathead4d
    flathead4d
    The most important thing with a 6 volt systems is proper size battery cables. 12 volt cables will not work well with a 6 volt system. Positive or negative ground makes no difference. make sure both cables are in the 00 range.
  7. stillrunners
    stillrunners
    from dallas
    Go with a 8 volt battery - how many times do I have to say it !
  8. Hnstray
    Hnstray
    from Quincy, IL
    ummmm.......apparently more than you have so far.......:D
    Ray
    blowby likes this.
