Just looking for simple black plug wires
Discussion in 'The Hokey Ass Message Board' started by Frank, Aug 3, 2008.
  1. Frank
    Frank
    Is it too much to ask? I just want a set of simple black plug wires that I don't have to pay an arm and a leg for. 90 deg boot on each end. Gotta be points style on distributor cap end. I want to cut and crimp myself on one end. All I keep finding are wires with red/orange/gray boots or when I find a black wire, its got all this bright large writing.
    This is going on a SBF. Any suggestions? The closest I've found was some Jegs carry.
  2. Rusty
    Rusty
    Gotto a older auto parts store all the new ones are carrying greay only now
  3. Tcoupe
    Tcoupe
    I got some black wires with black boots at Autozone...they were pre-made though..for sbc. The white letters came right off with carb cleaner
  4. vintagehotrods
    vintagehotrods
    ACCEL makes a set that you need. My 2005 ACCEL catalog shows the 8 mm Superstock 400 Series in black with 90 degree boots that you cut to length and attach the distributor 90 degree ends. I think the part number is 4041B, but check to make sure. I think Advance Auto can order them for about $36 a set.
  5. dave lewis
    dave lewis
    from Nampa ID
    Tractor supply has 4 cyl sets w/ crimp on ends. About $10 bucks. And they are real wire !!
    Dave
  6. squirrel
    find an old auto parts store that still has an old roll of wire and all the boots/terminals...
  7. Muttley
    Muttley
  8. DollaBill
    DollaBill
    Frank...if I could, I would...
    That being said.. 90 degrees at the plug is all good, but you need options...
    http://www.brillman.com/
  9. DollaBill
    DollaBill
  10. comp
    comp
    from So. IN.
    thanks :D
  11. 327-365hp
    327-365hp
    from Mass
    I bought Pertonix universal wires, black 7mm, no lettering and they come with dk grey boots.
  12. Moloko
    Moloko
    Accel makes all black custom fit sets.
  13. side_valve
    side_valve
    Alliance Vendor
  14. TheFrenZ
    TheFrenZ
    from Germany
  15. invizibletouch
    invizibletouch
    from Mobile, AL
    Just picked up a set at O'Reilly's yesterday. 15 bucks, black wire, dark gray boots.
  16. Bruce Lancaster
    Bruce Lancaster
    "4041B"...I believe that it is still true that the bright yellow Accel sets can all or mostly be ordered black by adding in that "B". If you want pre-terminated stuff, this gives you lots of options.
  17. Bluto
    Bluto
    You can call these guys
    They will do anything you want no extra charge
    And you'll not be needing another set for a very long time
    Good people good product
  18. i had the same issue earlier this year. i found these at my local "bumper to bumper" auto parts store. they look grey in the pic, but, they are black.
  19. tommy
    tommy
    This guy has what you need. For the old timers the Packard 440 lettering is a plus. Packard 440 wire was a hot rodder's upgrade in the early sixties.
    I bought a whole roll of it off of Ebay real cheap.
    I detest anything but black plug wires...purple, lime green, yellow? please...:D
  20. partsman
    partsman
    Go by any NAPA store, I run a NAPA store and have all the parts you need on the shelf to build plug wires, wire by the foot, individual boots and ends if you want to custom build a set. Its also very inexpensive. I make wires for Hot Rods, Tracters and old bikes all the time for my customers.
  21. hot-rod roadster
    hot-rod roadster
    from Omaha Ne.
    Moroso universal fit 8mm 90 degree plug boots ( black ) part# 73271 Gary
  22. vintagehotrods
    vintagehotrods
    If you plan on having a radio and listening to it, you had probably better stick with the resistor core wires like Accel or Taylor.
  23. lodaddyo
    lodaddyo
    these are the ones i ordered for my SBF, got them from jegs. worked out ok
  24. leadsled01
    leadsled01
    I use hand cleaner to remove the bright lettering on my plug wires.
  25. Bob Dobolina
    Bob Dobolina
    x2 the main counter on Military parkway should have everything you need.
  26. I got MSD black wires (7mm) from Advance Auto Parts. I think they were regularly $42 and they had them on sale for like $36. Good set and good ends with a tool to install the ends. I was impressed with that part. Two different kinds of ends too. I got a "OEM set" for my '56 from Summit that were Petronics and they were way too short. Had to send them back. They already had the ends on them. The MSD's were perfect for me. Lots of extra wire too. 2008-07-30 016.jpg
