Technical Just when I thought I have seen everything, a vintage quickchange transmission
Discussion in 'The Hokey Ass Message Board' started by Cliff Ramsdell, Oct 15, 2022.
  1. Cliff Ramsdell
    Cliff Ramsdell
    Morning all,
    Thought I would share this. I feel like I have a pretty good overall knowledge of automotive stuff, old, racing, people and such and every once in a while I stumble across something I have never seen or heard of before. Behold a vintage Chevy 3 speed transmission with a quickchange unit on the back, pretty cool. I put the link in here and added pictures for the future.
    https://www.facebook.com/marketplac...h&referral_code=null&referral_story_type=post
    Cliff Ramsdell
    Text from the add,
    Winters Performance quick-change mated to a 1965/66 GM Saginaw 3-speed transmission. Winters quick-change 10-spline base PN 6474. Winters 10-spline gear set #29, 24/15. Provides either .625 reduction or 1.6 increase in gear ratio. Saginaw 3-speed, PN 3868986. Date code C286. Gear ratios: 1st 2.85, 2nd 1.68, 3rd 1.0. $800.00 Also have a vintage bell housing/****ter shield for another $150.00
    DEEC6686-8D11-4C8C-8133-753CBDF69A0B.jpeg 8F250334-96F9-48F7-9137-0C52D29B7F06.jpeg 1B75A25B-8B1E-470A-89EE-1BFE71C4BBCA.jpeg B791565E-BECB-45EC-BDEF-1126430C5DAD.jpeg F0273C50-A0B8-47CF-B847-AE72BCD96258.jpeg A74D3351-9AE2-4323-BB8A-C59AF2CDB2C7.jpeg
  2. Boneyard51
    Boneyard51
    I would think that would make a lot of noise!
    But it is kool!
    Bones
    Cliff Ramsdell and SS327 like this.
  3. Tim
    Tim
    from KCMO
    I’ve seen one here maybe once? Really neat piece of equipment thanks for sharing! Good to see your name pop up :)
    Cliff Ramsdell and Algoma56 like this.
  4. dirt car
    dirt car
    from nebraska
    Back in the day would have been a sneaky way to fudge the rules where a quick change wasn't permissible, at least less obvious.
  5. AHotRod
    AHotRod
  6. Max Gearhead
    Max Gearhead
    from Wisconsin
  7. Thanks for posting that, never saw one before.
    Cliff Ramsdell likes this.
  8. Happydaze
    Happydaze
    Cool, but wouldn't exactly be quick to change!
    Chris
    Squablow and seb fontana like this.
  9. bchctybob
    bchctybob
    Love oddball stuff like that, thanks for posting.
    Boneyard51 and Cliff Ramsdell like this.
  10. Dave G in Gansevoort
    from Upstate NY
    As I recall reading way back, it was intended to lower unsprung weight. And the same 10 spline qc gears as used in the Winters or Frankland qc rears fit, so there's a wide range of ratios available. Also I seem to remember that they recommended the drive shaft have a slip joint in it that had enough travel to allow the cover to be removed without dropping the driveshaft.
  11. adam401
    adam401
    Ive seen alot of things but that's a first for me. I want it!
  12. studebakerjoe
    studebakerjoe
    Used to see them advertised in the old Stock Car magazines.
  13. Cliff Ramsdell
    Cliff Ramsdell
    Thanks Tim. It’s very busy here and I don’t always have something to add but I thought this was pretty damn neat.
    Cliff Ramsdell
    Max Gearhead and Tim like this.
  14. Several companies made them I have an add (VTH? was another company that built them) I will have to find it; they were built for oval track racing cl***es that did not allow quick change rears.
    The also were an advantage in less unsprung weight.
  15. dirt car
    dirt car
    from nebraska
    Would love to toy with one, no need to alter the rear crossmember or spring for clearance only drive shaft alteration as I see it....less impressive rear view but precisely as intended to the compe***ion.
  16. 48fordnut
    48fordnut
    Thanks for sharing.
    I have not seen one before. Good to see you posting.
    thanks,
    jim
  17. choptop40
    choptop40
    ive seen a lot quick changed diapers.... morning humor......he he he
  18. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    Super cool engineering.
    @Curt Six may get a kick out of this.
  19. XXL__
    XXL__
    Ovunderdrive?
    alanp561 and seb fontana like this.
  20. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    Yes, they were a thing. We made a variation of our own. The one shown uses two sets of QC gears so that the driveshaft still turns the counterclockwise (from the driver's seat).
    Ours just used one set and we flipped the rear axle.
    By using magnesium castings, aluminum axle tubes, gun drilled axles etc. we cut 125 lbs of unsprung weight. Admittedly, the old QC was not on the Jenny Craig diet.
    The car was fast, and totally awesome in thee handling department, but changing the gears was a headache.
    One season and back to a Quickchange. about a 15 lb. gain in unsprung weight.
    I still have the pieces if anyone is interested.
    Cliff Ramsdell and Tman like this.
