Justin's 1930/1 Model A Roadster build thread
Discussion in 'The Hokey Ass Message Board' started by 510madmav, Jul 29, 2010.
  1. rocksolidnate
    rocksolidnate
    from Viroqua Wi
    Great work, keep the pics coming
  2. Smokeshow
    Smokeshow
    I really have enjoyed reading this thread! I really like your truck ( and I don't say that about Ford trucks often:) )! This car will turn out to be super nice when done! Really good pictures as well do***enting the build...
  3. 510madmav
    510madmav
    Plugging away on the steering arm. I'll figure out how I'll weld it up tomorrow at the shop, also some gusset work. Had to tack using oxy acet tonight, also nevermind the lower shock mounts, not using those.
  4. 510madmav
    510madmav
    brainstorming a little bit on how I want to gusset the ball stud.
  5. 510madmav
    510madmav
    Got some stuff done today. Started exhaust too, ordered a roll of material which came in today, some flanges, and some tubing for the header flange stubs, & went to town.
  6. 510madmav
    510madmav
  7. bobo1
    bobo1
    from France
    very nice job
  8. 510madmav
    510madmav
    Just need to figure out something nice here..
  9. looking great!!!
  10. 510madmav
    510madmav
    Thanks Skater
    Today I grafted my early 1940's steering wheel taper/key onto my F1 column, because I like the early 40's wheels better than the later splined wheels.
    Here's how I did it.
    turned down a dowel key that would slip the two pieces together.
    Then I faced the two column pieces .
    Drilled holes for my rosette welds.
    Clamped in angle iron for true
    some nice hot welds.
  11. 510madmav
    510madmav
    Anyone have one of those long, early Ford truck column drops they want to sell me?
  12. Ford Mike
    Ford Mike
    I have one out of a 34 ford truck that someone cut instead of taking the steering column out the right way. The actual drop from the dash is intact but where the column mounts will need some serious attention. If you want it, its yours for shipping.
  13. 510madmav
    510madmav
    Thanks Mike, Got a photo?
  14. Vetteman61
    Vetteman61
    from Tennessee
    Did you mig weld or stick weld that steering arm piece? It looks nice.
    For what it is worth, I also would have strong reservations trusting the arm that was heated and twisted in the manner that it was.
    Brandon
  15. Ford Mike
    Ford Mike
    Not off hand, I'll dig it out tomorrow and take a pic on instagram and tag you in it since I don't have a camera other than my phone camera.:eek: Or I could email it, either way works for me.
  16. 510madmav
    510madmav
    Instagram works. jwk90
  17. 510madmav
    510madmav
    neither, Heli arc. As for the pitman arm, I'm lookin into it. thanks!
  18. Vetteman61
    Vetteman61
    from Tennessee
    Ah, OK. I'm not familiar with Heli Arc. I taught myself to weld last year. Do you think Mig welding a steering component would be strong and safe enough or if I do one should I use a different method?
    Thanks,
    Brandon
  19. HellsHotRods
    HellsHotRods
    My input:
    -Get another pitman arm and reverse it and reverse the bend, do not put a twist in it.
    - Bend that steering arm to the contour of the dropped axle, this get's your drag link closer to the same angle as your wishbone.
    - You placed a steel dowel in your steering shaft.....but now you can't run a horn rod or any wires in there.... I would re-thin this.
    That's my .03
    I love the build.
  20. 510madmav
    510madmav
    Thank you for the input. I see what you're saying about the pitman arm.
  21. 510madmav
    510madmav
    It's just an old term for TIG. If your base metal is prepared correctly, and your MIG is hot enough then yes.
  22. Vetteman61
    Vetteman61
    from Tennessee
    OK, thanks. I've enjoyed this thread and look forward to seeing it to the end
  23. hotrodderhaag
    hotrodderhaag
    Look at the build in my signature .. It has a column drop. I could get you one
  24. 510madmav
    510madmav
    Got my drop figured out, just got to come up with a bracket under the tank. It was the perfect length, I had to shim the column to the I.d. Of the rod with hose. Which acts like an isolator .
    V8 60 rod
  25. Beau
    Beau
    Oooooh! I like that. Sleek looking.
  26. 510madmav
    510madmav
  27. 510madmav
    510madmav
    Came up with this in a lickity split today after work
  28. Beau
    Beau
    Oh hell yeah! I must admit I'm not a fan of pistons rods, but that is a wonderful way to swap my opinion! Nice work!
  29. 510madmav
    510madmav
    Cool , thanks man. I wasn't a fan either. In most situations I'm still not.
  30. Babyearl
    Babyearl
    I have to agree,, Nice work.
