K&N filter test results
Discussion in 'The Hokey Ass Message Board' started by geez63, Mar 10, 2010.
  1. geez63
    geez63
    from Maryland
    I removed my air cleaner at the track last year because the Jegs 14x4 filter I bought ( that was adverised to have air flow that was similar to the same size K&N filter ) cause my car to run about a half second slower than when I ran it without a filter. I didn't like running the car without a filter so this year I decided to bite the bullet and pay the extra money for the K&N filter, 14x4 race filter ( #E-3730R ), XSTREAM filter lid, and their STUB STACK. What worked I was going to keep and what didn't I was going to send back. I know their are a lot of variables, so the results that I got won't necessarily be the same as someone with a different set up. I have a 55 Chevy, 3700 lbs., 350/350hp sb, turbo 350 trans., 2800 stall, 3.90 rear, 275/60/15 tires. I thought that anyone with a similar set up to mine may be interested in the 1/4 mile ET results of my test last week at our local tracks opening test and tune weekend. Below are the results.
    1st run - no filter - 13.79
    2nd run - with filter - 13.80
    3rd run - with filter & Stub Stack - 13.81
    4th run - with filter, Stub Stack, & XSTREAM filter lid - 13.85
    I repeated the same four runs with a 20 min. cool down period between each run and had similar results. The air temp. stayed within a few degrees all day and I ran in the same lane every time, also, my car is a little more consistent if I let it shift itself so that's what I did.
    As you can see, the K&N filter did perform better than the Jegs so this year I can run with a filter and not loss any performance, but the EXTREAM filter lid and the Stub Stack didn't improve my cars performance at all.
    K&N's race filter is advertise to flow 200 cfm more than their Universal filter of the same size ( 1200 cfm to 1000 cfm for a 14x4 ) but it doesn't filter quite as well, so I plan to us the race filter at the track and keep the Jegs filter for street use.
  2. mac762
    mac762
    I wonder how it would have went if you used a clean paper filter? Thanks for posting your findings.
  3. Petejoe
    Petejoe
    from Zoar, Ohio
    If I was running for best time on a track. I would not use any filter but only a panty hose material and change it every time I run it. That'll give you all the air your engine wants. I'll be interested to hear the responses I get from those running the tracks.
  4. Rich1028
    Rich1028
    I did a test like that on my car at the time,and it went better with the air cleaner
    on (k&n with XSTREAM filter lid) than without an air filter.
    so no more dirty carburetors for me.
  5. One of the rags did a dyno filter test with the K N extreme and it produced a couple more hp. I know some of you guys will hate this but I just bought a used one time K N 14 X 3 with extreme lid for 40 bucks off craigs list. The guy had it on a flat bottom boat with an open engine, it rained the afternoon he put it on and didn't realize the extreme top would let water through.
    I already had a 14 X 4 element on my 41 so I added the extreme lid to that.
  6. Flat Ernie
    Flat Ernie
    Tech Editor
    Don't know about the run, but since the K&N flows more air, it'll flow more dirt too. Had an experienced engine builder tell me this a long time ago - saw an article on it about two years ago too.
    Great for track, not sure I'd run 'em on a daily if I was in a truly dusty dirty environment...normal around town? Probably.
  7. bulletproof1
    bulletproof1
    from tulsa okla
    we ran them in our offroad rigs,,mainly cause you could wash them out ..didnt use the lids though....
