Projects Keeper Coupe
Discussion in 'Traditional Hot Rods' started by trevorsworth, Dec 27, 2024.
  1. RodStRace
    RodStRace
    Make sure the WPs line up with the other pulleys and order the thick belt ASAP. That's one of the little parts that can hold things up.
    See if you have ignition, carb and gaskets in local stock too. Hopefully the shop has enough sway to get things local, even if they end up going back to the warehouse.
    54delray and Outback like this.
  2. trevorsworth
    trevorsworth
    I still remember the gut drop I felt the first time I pulled the head off a running engine. "Oh God, what have I done? Will this thing ever run again?"
    Fortunately now it's becoming pretty routine.
    This cylinder has even compression with all the others lol. Looks like a spark plug tip got dropped in there... it ran, so, **** it.
    Got it pretty clean & pretty far apart today. Hopefully tomorrow - weather permitting - we'll get some paint on it.
    Hot rodding in a lube shop means staying out of the way. Glad I have a patient boss.
  3. trevorsworth
    trevorsworth
    Block is painted. Using the heads, intake and junk water pumps to mask the gasket surfaces (since they still need to get prepped and painted). The oil pan also needs to come down to get properly cleaned before paint. Still thinking probably white heads and intake.
    Perfect? No, but it's a dump truck engine going in a 70 year old hot rod that has structural coat hangers. It's gonna look pretty damn fine...
  4. RMONTY
    RMONTY
    Who said you could paint my engine? Technically it's still mine....unless you are going with the possession is 90% of the law kinda ****!!!o_O
    Jeff34, Thor1, Stogy and 3 others like this.
  5. RMONTY
    RMONTY
  6. RodStRace
    RodStRace
    Have you priced paint lately? You probably owe him! :p:p
    Budget36, Stogy and porkshop like this.
  7. kls50
    kls50
    Not that you don't have enough to do, but would it be a good time to push the engine outside and flush the block before you replace the water pumps? I like the red and white.
  8. RMONTY
    RMONTY
    Have you priced decent running flathead engines? Think again buckaroo!!
  9. RodStRace
    RodStRace
    @RMONTY I saw your SD thread and did a very quick skim through it. Nice work. I'd only seen you in Trevor's posts.
    I'm sure not trying to get into the middle of you two Texans tussling over a flathead, just goofing!:)
  10. RMONTY
    RMONTY
    Trevor knows I'm giving ****. We are the best of friends. We break a lot of stuff together.
    If you haven't seen it, check out Trevor's first thread "Jumping in the deep end" I think it's called. I wasted a lot of time training Trevor to fix things right, and now look at him go! I am super surprised he is actually painting something!!
    https://www.jalopyjournal.com/forum/threads/jumping-in-the-deep-end.1201655/
  11. RodStRace
    RodStRace
    I remember the gas tank strapped to the tractor wheel without even going back! :D
    Jeff34, porkshop and trevorsworth like this.
  12. wheeldog57
    wheeldog57
    That piston looks like a Tomase's English muffin, yikes!!! Keep at it boys it's great to see the young-ins building old hot rods.
  13. RMONTY
    RMONTY
    It's nice to be called a young-in since I officially became a senior citizen a few weeks ago, but Trevor is definitely a young-in....but has his **** together and is a damned fine hot rodder! I'm proud to call him a friend!
    Paul B, porkshop, wheeldog57 and 3 others like this.
  14. trevorsworth
    trevorsworth
    Might not hit the target on getting the engine together tomorrow but we're inching closer...
  15. 38Chevy454
    38Chevy454
    Keep doing the small things, and soon the big things are done.
    I'm not a flathead guy, but I think that old truck hoghead bellhousing is what is used to mount a newer open drive trans, such as a T-5 with a simple adapter plate. So that may bring some money in as a swap meet selling part. A more knowledgeable flathead guy can confirm. But if you plan to keep the old Ford 3 speed trans, that hoghead and cross shaft may be worth some money. The old big truck trans itself is no more than s****, but save the bearing retainer off it.
  16. trevorsworth
    trevorsworth
    I'm not planning on running the byp*** filter (at least not on the head). Is it OK to just plug the in/out ports or should I connect them to each other? I'd like to go full flow with a spin on filter but I'm not ready yet.
    porkshop likes this.
  17. dwollam
    dwollam
    For me it's a NOPE on the white head. Sorry.
    Dave
    warbird1, porkshop and trevorsworth like this.
  18. trevorsworth
    trevorsworth
    No problem haha. I wasn't sure myself. I think I like it, but until it's sitting in the car I won't really know. Easy enough to shoot some red enamel on them later if it doesn't turn out the way I'm hoping. Either way, these heads aren't staying forever. Sid has a couple sets of finned aluminum heads in the stash and I'm intending to make an offer to Guy on one or the other.
    dwollam, Thor1, porkshop and 2 others like this.
  19. trevorsworth
    trevorsworth
    Now if I could just get an hour or so to prep all the gasket surfaces & bang this turd together we'll be cooking.
  20. MARKDTN
    MARKDTN
    You are probably aware of this but be sure that the flywheel you get is for an 8BA with 10” clutch (not an earlier V8). The easiest way to tell is if the pressure-plate bolts are drilled all the way through. If they are blind, it is an earlier style and will not work-even though it will bolt up.
    trevorsworth likes this.
  21. ididntdoit1960
    ididntdoit1960
    from Western MA
    Yup - sold one just like it a month ago for $950
  22. trevorsworth
    trevorsworth
    I wouldn't have known how to tell but I trusted Iron Trap who I bought the flywheel from. Incidentally, it turned out that this engine already had a 10" flywheel (but the clutch was rusted to it and would have needed to be resurfaced anyway). I never bothered checking because I had always heard the big trucks had 11" flywheels, but this engine has been rebuilt, so who knows.
    I don't remember what I paid for this engine now, but it was 5 years ago and doesn't seem like it was much. $250? It was non running and had been outside for a while but fired right up for us after unsticking it.
  23. Grumpy ole A
    Grumpy ole A
  24. trevorsworth
    trevorsworth
    We were very busy today but was able to get the heads installed. Got the transmission bolted up & we were all fired up to try and stab it in but for some reason the clutch plate seized on the input shaft and now won't come back apart. Having some difficulty separating them... I am going to try to get behind the bellhousing and unbolt the pressure plate from the flywheel.
    catdad49, Okie Pete and porkshop like this.
  25. trevorsworth
    trevorsworth
    Sid had the engine LOW. But it's in. Clutch linkage fell right in place & works perfectly... one pedal down, two to go.
    There is really no provision for the transmission mounts. Not sure what Sid had going on for that. I'll figure something out.
    Obviously, this will be coming back out soon - the frame and body need paint after all.
  26. Was curious how you were going to go with the paint
  27. trevorsworth
    trevorsworth
    I need to buy a SCT or something and get after it when it warms up, but I do intend to paint the whole car. Another week of ****ty cold weather ahead of us in Texas so I want to get some of the mechanical stuff out of the way... going to try and fab up a trans crossmember and exhaust while it's too cold to paint.
    catdad49, Okie Pete, porkshop and 4 others like this.
  28. Well I was already a fan of your build. I had feared you were in the "patina" crowd as I hadn't really noticed any reference to paint previously. But I kept quiet as it was still cool. You're last couple comments raised the cool level a few pegs lol
  29. trevorsworth
    trevorsworth
    Haha- I can appreciate nice patina but this car has rust, not patina. It needs to get fixed. Sid rolled 3 different kinds of house paint onto it - so I don't feel a big need to get a perfect paint job on it, but I want it to look nice.
    catdad49, Okie Pete, porkshop and 9 others like this.
  30. What color(s) you thinking? If you were closer I'd be down for helping with paint prep. I'm known for moving fast in that area lol
    porkshop and bchctybob like this.
