Keeper?
Discussion in 'The Hokey Ass Message Board' started by 1low52, Apr 15, 2012.
  1. 1low52
    1low52
    Good morning all. Sorry for the early am brain teaser but trying to get together some $$$ to pay my taxes tomorrow. :mad:
    I have a rusty 70 Ford van I'm stripping of anything useful before sending to the recycler. I had planned to pull the rear thinking it might be useful for a future project but when I got a good look at it I began to wonder if it was worth messing with.
    I'm not very knowledgeable about Ford rears and this one doesn't look like any other 8" or 9" that I've got.:confused:
    Is this thing something I should keep or send down the road?
    Thanks
  2. Willy301
    Willy301
    That looks like a 9 inch to me, a shot from the back would tell the story though..
    That bolt, partially obstructed by the input shaft housing is usually a dead giveaway that it is a 9 inch...Definitely worth keeping...
  3. sko_ford
    sko_ford
    In the van that will be a nine but it will be wicked wide. That can be fixed & i will be 5x5.5 bp.
  4. 06 pitbull
    06 pitbull
    from GA
    looks to be a 9in... I have 1 also.. the axle tubes are straight on my van housing..this makes it easy to cut it down to narrow..this is the reason I am going to keep it.. I have found some housings step down or taper.. the straight tubes are easy..
  5. Deuces
    Deuces
    Yep! That's a 9 incher in the rear...
    DOH!.. That didn't sound right!...:rolleyes::eek:
  6. yep id keep that 9 inch from drum to drum
  7. Stevie Nash
    Stevie Nash
    Good stuff! lol
  8. 1low52
    1low52
    It's 61 1/2" backing plate to plate.
    If it's a 9" I'll give it a go and add it to my stash.:D
    Thanks.
  9. anteek
    anteek
    Wide 9 inch with PROBABLY a 3.50 gear,maybe 31 spline...............keep it to flip in pieces.
  10. 56don
    56don
    Might it be a 9 3/8 inch? Did they come in vans? I have one of them in a 70 Lincoln.
  11. BamaMav
    BamaMav
    from Berry, AL
    Some of those vans had a 9" with an offset chunk. Narrow it to the same length as the short side, use a short side axle, and presto, cheap narrowed rear end!
  12. fab32
    fab32
    X2 keep it and if you don't use it it will be good trading stock for someone.
    looking to make a narrow
  13. Its a 9---
    Quick way to tell is you CANT get a 9/16 deep socket & ratchet on the bottom pumpkin stud...keeper!
