Keeping aluminum intake looking new.
Discussion in 'The Hokey Ass Message Board' started by voodoo1, Apr 14, 2013.
  1. voodoo1
    voodoo1
    Whats the best way to keep a new or re-new aluminum intake manifolds looking new? Mike
  2. scibjenkins
    scibjenkins
    I've used Simple Green to clean aluminum parts that had greasy hand prints and dust and dirt. But it was still fairly new (a few months old). Cleaned it right up and made it look fresh out of the box. But as far as anything real old, I would suggest maybe media blasting?
  3. GassersGarage
    GassersGarage
    I use laquer thinner.
  4. Lemon pledge. Give it a good soaking then let it air dry for a few hours. Wipe it down. You'll have to repeat the process about once a year, but it will keep your intake in a condition that a quick rinse once in a while will keep it looking like new.
  5. black 62
    black 62
    from arkansas
    regular power washes...
  6. swifty
    swifty
    Jet-Hot coating. You can polish any fuel stains off and most will wipe off if you get to them quick enough.
  7. R Frederick
    R Frederick
    from illinois
    I use MAC's aluminum cleaner from NAPA. It's basically Phosphoric acid that re-etches the aluminum. Looks brand new when done.
  8. mashed
    mashed
    from 4077th
    Have it media blasted and clear powder coated. Or keep it on the shelf.
  9. Falcon Sprint
    Falcon Sprint
    When I restored a set of aluminum valve covers, I media blasted them first and then coated them with fresh/new engine oil and let it soak in before wiping it off.
    Later, if it got dirty oil of them, it wouldn't soak in a leave a stain, it would wipe off.
    They looked great, looking new for several years until I sold the car.
    Sounds strange, but it worked better than any other method I've tried.
  10. HOTRODPRIMER
    HOTRODPRIMER
    Yeah,this works. HRP
  11. chubbie
    chubbie
    I did several blast/clear powder coat, not good:(
  12. Oldstrk
    Oldstrk
    Had my aluminum intake clear powder coated when new still looks new 4 years later
  13. Roger Walling
    Roger Walling
    Close the hood and drive it while you are working on the next project!
  14. greenone
    greenone
    I had mine ceramic coated dull silver...looks just like brand new cast aluminum, and has been looking that way for 2 years and lots of driving. Fuel and other stains wipe off easily.
  15. hdman6465
    hdman6465
    Media blast , then use Eastwoods Aluma Blast. This is the closest color I have found to keeping it look like it was never fooled with. Simple Green when it gets dirty.
  16. Blue One
    Blue One
    from Alberta
    If you want to keep the raw cast aluminum look it will as you know be vulnerable to stains from a variety of things.
    A solution as mentioned is to have it powder coated, Eastwood sells a cast aluminum looking powdercoat.
    If the raw aluminum is what you prefer to keep, look up a product called Aluminum Jelly.
    It's a cleaner that will best keep your manifold looking new.
    Edit : By the way if you use any form of mechanical cleaning method like the next poster suggests - wire brush, say goodbye to the untouched raw aluminum look.
    You may as well have it powder coated in color.
    And I can't believe someone actually suggests WD40 as a cleaner :rolleyes:
  17. no55mad
    no55mad
    WD40 and a stainless steel wire brush (tooth brush size to get in the nooks and crannies).
  18. 4rod
    4rod
    as said, a good cleaning with an abrasive, I like WD40...with steel wool...seems to help sealing it as well...the PO had painted mine so I cleaned it up as good as I could and hit it with cast paint...media blasting would be the ticket to really clean out the pours though...
  19. goldtele
    goldtele
    I've had good luck having them sandblasted then clear coating them.
  20. Eslope T
    Eslope T
    Try Meguiar's Hot Rims aluminum wheel cleaner. Spray it on, rinse it off with water. Remove a lot of gas stains.
  21. 39 Ford
    39 Ford
    Painting with Aluma blast works just fine, I do all the underhood aluminum with it alternator etc. I do not do valve covers and air cleaners however.
  22. 340HilbornDuster
    340HilbornDuster
    I used "Etching Mag Cleaner" - It works great!
    Labeled - Not recomended for painted or polished wheels!
    AVAILABLE?
    I haven't seen it in the store lately...maybe they discontinued it...?
    I have a stash at home though!
    SOON:
    To do it again (I'll be doing it shortly when the intake is out)
    I plan on removing all the stuff, injectors, sensors, hoses etc.
    .....It is etching!
    Aloha
    Tommy
  23. OLLIN
    OLLIN
    I've used oven cleaner from the .99 store. Works ok for cheap..
  24. diegochero
    diegochero
    Same thing as Eslpe T, I use eagle one mag and aluminum cleaner. Spray it on, rinse it off, easy! The only problem is then you have to clean the rest of the engine compartment.
  25. jjjmm56
    jjjmm56
    from FL.
    when on the car I use contact cleeaner
  26. mustang6147
    mustang6147
    from Kent, Ohio
    I also paint the aluminum with High temp engine paint...
  27. customrod48
    customrod48
    a good cleaning, and a clear coat.........I have also painted silver and clear coated, made cleaning it later alot easier. Dirt and stains seem to not stick to the coated surface. Don't clean the clear coat with an agressive abrasive or it will scratch.......
