Technical Key Delete Chevy steering column
Discussion in 'Traditional Hot Rods' started by Dobrosailor, Mar 4, 2022.
  1. Dobrosailor
    Dobrosailor
    My 38 has a typical '70s/80s chevy tilt steering column with the steering lock that has the big wings. I want rid of the key and molding around it so its just a cylinder with the tilt and signals arms protruding only. Anyone done or seen it done clean? My dream would be a thin cylinder to slide over it and 10 minutes with my bench grinder.
  2. SS327
    SS327
    That’s what I would do. Or just fill the big hole.
  3. junkman8888
    junkman8888
    Many moons ago shaved the key off a tilt column as I wanted to keep the key on the dash in my '63 pickup. You need to dis***emble the steering column at least to the point of being able to remove the "sleeve" in question (whenever I get into a column I just go all the way, cleaning, checking and lubing everything, also don't forget to put loc***e on the four swivel knuckle bolts).
    Back to the sleeve; Remove the lock cylinder, cut off the offending portion of the lock boss with a sawsall, then grind the lock boss area so it is slightly below the surrounding area (in other works, "dish out" the area where you cut off the lock boss) Degrease the former lock boss area (I use a small bristle brush and lacquer thinner) cap off the inside of the lock boss hole with tape then fill the hole with pieces of fibergl*** mat and resin. Grind and repeat until the hole is filled, sand and prime. I did mine at least twenty years ago, hasn't cracked yet.
    Upon re-***embly, always put one part on, test the column, then move on to the next part, if you try to get it done all at once I promise you'll be taking it back apart.
  4. banjeaux bob
    banjeaux bob
    from alaska
    Some Chevy "P" series cab/ch***is from the 70's had a tilt column with the key in the dash.
  5. Johnny Gee
    Johnny Gee
    from Downey, Ca
    I've done it. Cut off boss and reshape. Make a stepped recess below the finish surface then JB weld a plate onto the step created. Next day use body filler, shape, prime, block out then paint. No sign of being plugged. It's been nearly 20 years.
  6. Tilt columns are not era-correct.....
  7. Mr48chev
    If it is pre dimmer switch on the column it can clean up pretty easy. I agree with taking it apart far enough that II have that part of the housing out where I can clean it up and work on it.
    I used to have to take them apart on a regular basis to tighten up the three screws that hold the thing together because short fat wife would use the steering wheel to pull herself up so she could reach the key or the dash. I'm thinking that those three screws that take a torx bit are the same ones that hold the part that holds the lock cylinder. It seems like I had to pop the lock cylinder out to get to one of the screws every time. I don't know if I have one left worth playing with but I'll take a look and see if I can do a step by step on taking one apart.
    That's if I have one left as I tossed a bunch of them in the last load of s**** I hauled after keeping some of them for 30 years.
  8. SS327
    SS327
    Even the ones with the dimmer switch should be easy. Just remember to take out the lock pin and rack with the rod. You are going to need some special tools also. Lock plate depressor, and a pivot pin puller. In my glory days I could rebuild a GM tilt column in 10 minutes start to finish replacing shiftbowl and lock housing and side cover. That included pulling the steering wheel. I would paint all parts first before starting and and pull all needed parts and tools.
  9. 427 sleeper
    427 sleeper
    Would it be possible/easier to swap an early/mid sixty's Impala tilt steering column? Smaller O.D and no key, only tilt and turn signal lever's. Just a thought...
    Dobrosailor and scotty t like this.
  10. choptop40
    choptop40
    tilt columns were option in 1963 for the fact checkers...period correct for the Hamb....
    SS327, '34 Ratrod, loudbang and 5 others like this.
  11. 57 Fargo
    57 Fargo
    The tilt Column in my truck is out of a ‘70’s G van, key was on the dash.
    Dobrosailor and chryslerfan55 like this.
  12. goldmountain
    goldmountain
    I put one of those columns in my '47 Plymouth way back in the 70's. I'm keeping it that way because that's the era the car is from.
  13. banjeaux bob
    banjeaux bob
    from alaska
    Try to find one that is not in a running car..... I had one from a '66 Impala with floor shifter....45 years ago.
  14. banjeaux bob
    banjeaux bob
    from alaska
    Easy to tell your wife does not frequent the HAMB.......
  15. nobby
    nobby
  16. choptop40
    choptop40
    I cut off the key buldge on a 70s column and just fibergl***ed that hole and voila ..of course remove the anti lock disc or plunger.....was easy peasy....those vintage 60 s tilt columns are hens teeth today......
    Bob Lowry likes this.
  17. Johnny Gee
    Johnny Gee
    from Downey, Ca
    What about the lock plate?
  18. cfmvw
    cfmvw
    Just remove the locking plunger pin and related components. That's what I did when I shaved the key boss off a '70s GM tilt columns. As others have, I used JB Weld and a piece of aluminum to fill the hole where the key used to be. I took mine completely apart and welded the four bolts mounting flange to a length of steel tubing to make a nicer installation out of it. Don't forget to loc***e the four bolts!
  19. BJR
    BJR
    Neither are the fat people that now need them!:D
  20. Bandit Billy
    Bandit Billy
    I hate skinny people from those nostalgic photos. And the term "fat fendered", too much body shaming going on. We need a "me too" movement up in this place. :cool: The French would never stand for this! Liberté de la roue inclinable
  21. BamaMav
    BamaMav
    from Berry, AL
    I'm thinking you have to keep the lock plate because it holds down the upper column bearing.
    chryslerfan55, SS327 and Johnny Gee like this.
  22. Johnny Gee
    Johnny Gee
    from Downey, Ca
    True, and if one were to file three more skipped tooth's @ 90 degrees of one another the retainer can be indexed. any where so horn contact falls more conveniently where one would like it.
    chryslerfan55 and Hnstray like this.
  23. The column in my avatar is a key delete style. Which I like because the ignition switch is on the dash.
  24. Dobrosailor
    Dobrosailor
    Thanks all, I am thinking a replacement Impala or van is easier since there is so much else to do, however of all the ideas I have hears I would probably wrap the entire cir***ference with aluminum and JB weld use some hose clamps to hold it in place till it drys. . I want to rewire it for a key tucked under the dash close to the original location on the steering column mount and a period correct starter ****on. Nothing like a separate starter ****on to set the context for a trip in a vintage car. I want to find a cool aftermarket banjo style 13-14" wheel and get a column that matches the diameter of the wheel hub. Not a fan of billet anything in a vintage hotrod. WOuld like to keep this one a period piece.
    427 sleeper likes this.
  25. choptop40
    choptop40
    the locking plate might have to remain...memory sometimes is tricky..removing the plunger would do it...
  26. bjinx
    bjinx
    Get a Chevy Van column, I believe '68 thru '74.
    Key was on the dash those years.
    They had tilt column
    I have used three of them over the years.
    '40 Ford Pickup
    '31 Model A (current project)
    O/T '70 C-10
