Technical Keyway
Discussion in 'Traditional Hot Rods' started by clyde28075, Nov 22, 2020.
  1. clyde28075
    clyde28075
    from concord NC
    Can anyone help me out with this Have a French block Flathead putting a **** rotating ***embly in it The crank came with out any woodruff keys i called **** and they gave me some dimensions that i cant find anywhere So i seen somewhere someone said a PK-9 woodruff key but i think it needs another number But Im not sure on that either. So any help i could get from the Group would be Greatly Appreciated . Im looking for the Crank Gear Key and the Lower pully key its a March lower Pully It looks to be around a 1 1/4 long the crank gear key looks about 5/8 long Please Help If You Can . Just cant believe **** would not include the Keys.
  2. Budget36
    Budget36
    I’d ***ume it would be the same as the crank you’re replacing. I/e a SBC v SBC **** would be the same
    The reason I say this I doubt they would expect you to buy some obscure pulley that matches up to their crank, you never know, I just kinda doubt it
    Desoto291Hemi likes this.
  3. If the crank key way is not machined like a Ford,,,,,,or takes Ford keys,,,,I suspect the **** crank .
    This was not a “second “ crank is it ?,,,,,,seems like a Flathead key should be the same .
    By the way,,,what are the key dimensions from **** ?
    Tommy
  4. noboD
    noboD
    I would send it back!
  5. jaracer
    jaracer
    My Ace Hardware has a woodruff key selection.
  6. dirty old man
    dirty old man
    My Ace Hardware has an ***hole for an owner.
  7. Flathead Dave
    Flathead Dave
    from So. Cal.
    My flathead came with a henway...
    VANDENPLAS likes this.
  8. :rolleyes::D Lol now that’s funny !! Always in stock premium ***hole !! Lololololol
    fauj and Truckdoctor Andy like this.
  9. dirty old man likes this.
  10. flatford39
    flatford39
    LOL....So does mine and the place is a mess.
  11. clyde28075
    clyde28075
    from concord NC
    **** Said 15/64 X 5/8 long and lower pully was same but 1 5/16 long if you try and look that up any where 15/64 does not exist 1/4 is closest and i can machine thickness to fit but the never gave a height dimension either Thanks for you help on this
  12. clyde28075
    clyde28075
    from concord NC
    Thank you everybody but still need help to solve this I may have found one in a old Crank i found have to check it out tomorrow i will let you know when i can go dig it out
  13. Mr48chev
  14. Clyde Im in Charlotte I if stock keys will work I can knock a couple out of a stock crank if it helps you out. Cheers
    Tony
  15. clyde28075
    clyde28075
    from concord NC
    Thank you Very Much for your help I went on Vanpelts and found the numbers you gave waiting for 900am going to call him and get them Thanks Again for your time and efforts
  16. clyde28075
    clyde28075
    from concord NC
    Thank you Tony May take you up on that. Checking the other Crank I have on Saturday And calling Vanpelts today and see if they have the ones that Mr 48 Chevy told me about .I will get back to you when I see what I can get I really appreciate the Offer Tony Thank You
