Hot Rods KickDown cable leaking help!!
Discussion in 'The Hokey Ass Message Board' started by kerwinq, Jul 16, 2018.
  1. kerwinq
    kerwinq
    from Boise, id
    Kickdown cable was lifted a little on the inside, bolt was only finger tight. Is there a boot or o-ring that goes in or would I be ok to put the bolt back in and tighten down correctly to see if it stops leaking? I just put a new trans pan on and didn't want to pull it off if I don't have to!
    Thanks, Kerwin
  2. krylon32
    krylon32
    from Nebraska
    There is a rubber boot that goes in the hole first.
  3. OLDSMAN
    OLDSMAN
    Some cables have an o-ring the older ones, all the later cables use a boot for a seal. If yours has an o-ring I would buy the later cable with the boot seal and fix the leak that way. The boot seal works much better.
  4. Gregg Pellicer
    Gregg Pellicer
    If the bolt was loose the obvious thing to do is tighten it up first. Then see if it still leaks if you do have to replace the seal removeing the pan is not necessary.
    Tim likes this.
  5. alwaysamopar
    alwaysamopar
    Yup...remove bolt. Pull cable housing outta case to where you can see detent . Grab detent wire with needle nose. Remove cable end from detent wire. Then replace oring/boot and reinstall. It's easier than trying to explain. Oh yeah and make sure plastic flange where bolt goes thru isn't cracked. If so you'll have to replace entire cable.
    Sent from my SM-G900V using The H.A.M.B. mobile app
  6. squirrel
    the bolt is missing, who knows what else is wrong with it!
  7. kerwinq
    kerwinq
    from Boise, id
    thanks for all the replies, I am going to put the bolt back on and see if that helps for the time being but plan on replacing the boot
