kickdown linkage
Discussion in 'The Hokey Ass Message Board' started by sqrlnts, Dec 27, 2012.
  1. sqrlnts
    sqrlnts
    Chevy 350, 72 lineage where does my kickdown linkage hook to? And what am I missing to make the connection? Thanks HAMB!
  2. Nonstop
    Nonstop
    from CA
    Unless I am mistaken (very well could be) you are missing the slotted eye at the end of the cable and a corresponding stud.....th 350?
  3. Risky
    Risky
    Yes sir you are correct. There should be a plastic clip on end of cable and a stud it snaps onto on the throttle arm.
  4. themole
    themole
    from So-Cal
    This is what most of the stock setups look like.
    This is a setup from Lokar.
    You may need to buy a whole new cable if you can't get the piece that goes on the end of yours. Note that the stud on the throttle arm has a flat head and not a ball end. You might need to make a trip to a junk yard to get the parts you need.
  5. sqrlnts
    sqrlnts
    Thanks alot guys!
