Kicking Up Dirt In A CycleKart
Discussion in 'The Hokey Ass Message Board' started by Ryan, Dec 27, 2007.
  1. nexxussian
    nexxussian
    Two caps? One for gas one for oil (oil injected 2 stroke maybe), or is one for show?
  2. anvilcustoms
    anvilcustoms
    For show. As are the "vents".....as is the "exhaust pipe". The exhaust pipe actually is there to create a more stable box to ride in. These are simply a four wheeled vehicle on a square tubing frame, wood box body (unless sheet is used), and a 6.5 HP horizontal shaft engine. Hilarious, and freakin' fun.
  3. 34Fordtk
    34Fordtk
    Ok I am hooked on these,BUT most of the pics I see they are running live axles but the guy from Stevproj.com says he/they only run a single wheel drive. What am I missing or was he saying that to throw everyone off ????
    Anyone else started building one yet?????
  4. anvilcustoms
    anvilcustoms
    There is no doubt he could be trying to THROW PEOPLE off.....However, you can run a live axle and only drive ONE wheel as long as the other wheel is FREE TURNING on the axle (not keyed, and plenty of grease.)
    Check out my Cyclekart Build page on my website: http://anvilcustoms.com/id78.html
  5. 34Fordtk
    34Fordtk
    Cool, Thats kinda what I was thinking he was doing. I checked yours out looks like a great start, what are you going to run for power??
  6. zman
    zman
    from Garner, NC
    C cl*** super karts in the WKA... dollar for dollar and pound for pound the fastest and most fun you can have roadracing... still running them though there are more in the 125 cl*** these days than the 250's
    A two stroke bike motor or in a Cycle Kart may be a bit much... but then again what the hell...
  7. butch27
    butch27
    What size wheels and tires do those use and what are they off of?
  8. 34Fordtk
    34Fordtk
    Butch, Most are running 17" from a Honda Cub but they are hard to find. I am going with some other wheels like Harley sportster fronts or something easier to find with a 3/4" axle.
  9. Jive-Bomber
    Jive-Bomber
    MODERATOR
  10. Tymen
    Tymen
  11. anvilcustoms
    anvilcustoms
    HEY ALL! I know its been ....well.....YEARS, but as promised, I have put together some parts to aid in your Cyclekart Projects. If you know anyone interested in cyclekarts....I'm here.
    Anyways, here is a site with some pics and parts. Its a NEW SITE and will be adding to it as time goes on. I'd much appreciate your feedback. Enjoy.
    www.cyclekartparts.com
    Peace,
    Ryan @ Anvil Customs
    www.anvilcustoms.com
  12. butch27
    butch27
    Those things still look like a load of fun. Are the fragile?
  13. anvilcustoms
    anvilcustoms
    Fragile? Depends. Driving on payment, I'd say industructable if built right. Offroad.....it'd crumble!
    The one I'm currently building will be very sturdy. Believe it or not, the parts (frame, front end, rear live axle) are VERY strong. The drop axle is 1 5/8" round tube with 1/8" walls! THAT IS STURDY.....
    You should build one! Yes, they are very fun.....Imagine you and your buds cruisin' to the next 50's car show at the diner.....you'd be the HIT of the SHOW! haha
  14. anvilcustoms
    anvilcustoms
    Yes, of course to throw people off. If you end up building one, you will find several other notes that are a bit "off" as well.....kinda funny really.
    Some of them are even impossibilities.....have fun.
    Ryan @ Anvil
  15. Huvius
    Huvius
    from Colorado
    I have been kicking around the idea of building a cyclekart for some time as well and am finally getting some parts together.
    A couple thoughts on my build and parts:
    Yes, the Honda wheels are getting high$$ so I have opted to use four front wheels from Honda CR80s. They are plentiful, light, cheap (got four for $217 shipped) and very strong. They are 17" so there are cheap tires out there and proportionately they look proper. I think the hubs look better than the drums too.
    I am thinking I can bolt the drive wheel to a flange through the disc brake mounting holes on the hub.
    I am toying with the idea of using an aluminum ladder for the ch***is - either a 5' step ladder or a section of straight ladder. Either way, they are cheap and can be found at recycling centers all the time.
    Any thoughts on whether that would be durable enough?
    I have an idea for the steering wheel which I will have to try prior to posting on it.
  16. 53sled
    53sled
    from KCMO
    What do you use for a drive hub on a front wheel?
  17. those things look WAY FUN!!!
  18. Huvius
    Huvius
    from Colorado
    The wheels used are FRONT WHEELS from the bike but used on all fours for the cyclekart.
    From the looks of it, the drive is accomplished through a keyed disc on the axle which is then bolted to the drum by drilling holes through the drum wall.
    You can see it on the rear hub of this car:
    I think I could do the same but have the flange bolted on the inside of the hub but maintaining the through axle for strength.
    The CR hub is this:
    The tabs for the disc rotor look kinda small but I think they will take it.
  19. Huvius
    Huvius
    from Colorado
    And here are my CR80 wheels with tires fit.
    The rims have a bead locking block just about opposite the valve stem so there is another hole in the rim about the same size.
    I considered plugging the hole but decided to keep the blocks in place. We will see if they have any effect on wheel balance.
    I think they look pretty sweet!
    motoklas likes this.
  20. cmarcus
    cmarcus
    BTT - keep this thread going! My buddy and I were first thinking about building a go-kart, which got me looking at Cycle-cars, and now to here! Man o man! Just would be a blast for a little weekend project to bang around on.
  21. butch27
    butch27
    These things look like a ton of fun.
  22. Huvius
    Huvius
    from Colorado
    Saw this on The Old Motor site.
    Pretty much the same formula for today's cyclekarts save putting the motor up front rather than in back as is the usual on most cyclekarts you see these days.
    http://theoldmotor.com/?cat=23&paged=39
  23. Huvius
    Huvius
    from Colorado
    My springs came today.
    They look pretty good although I was a bit surprised that the ends don't have alternate fittings at either end, meaning, in the setup as they are bolted together, one spring has the cover half and the other has the sleeve half.
    I expected each spring to have one end as the cover and the other as the sleeve which would make production cheaper since every spring would be the same and the alternating ends would nest in each other.
    Now, not wanting to buy more springs, I may opt to go 1/4 elliptic with the four leaf springs or transverse half elliptic front and rear.
    The two leaf spring:
    The four leaf spring:
    Ends of the 4 leaf showing what I was talking about:
  24. HOTRODPRIMER
    HOTRODPRIMER
    How in the world did I miss this the first time around?
    That looks like so much fun! HRP
  25. smcameron
    smcameron
    Cool, just found this thread, and this forum... Here are some pics of my cyclekart, mostly completed as of last summer:
    If you happen to be in Houston, you can see my kart in person, it's at Houston's hackerspace, TX/RX Labs. They have an open house every Friday night around 7:00pm and a pancake breakfast on Sundays around 11:00am. Lots of CNC machine tools and so on, very cool place.
    BTW, if you're building a cyclekart, there's a cyclekart forum... just search for cyclekartclub. 'Course if you're building one, you probably already knew that.
    -- steve
  26. Bigcheese327
    Bigcheese327
    That's a work of art, Steve! I wish the hackerspace thing would catch on up here.
  27. josh higgins
    josh higgins
    So after a few financially unrealistic race car build attempts, I finally finished one. Finished enough to race anyway.
    1920 Monroe cyclekart
    motoklas and rod1 like this.
  28. butch27
    butch27
    THAT is just too cool!
  29. T Hudson
    T Hudson
    Bringing up an old one here. I have almost completed my cyclekart and did some testing.
    Still a bit of bodywork to do.
    And the old chevy can haul it around. Double cool!
  30. Bigcheese327
    Bigcheese327
    Great use of tractor metal!
