Kid in Guatemala
Discussion in 'New to the H.A.M.B.? Introduce yourself here!' started by Rodereto, May 30, 2006.
  1. Rodereto
    Rodereto
    from Guatemala
    i have a 84 trans am whit a 305 soon to be a 350 whit 400+ hp (the parts are being shipt from jegs) my problem is whit the transmission i cant make it shift unter 2500 rpm between gears if tride to ajust the T.V. cable but if i go a litle tite ore a litle loos the tramsmission gose heywhire and dosent shift until 4500 rpm, someone told me that there are other ajustments on the gear box but i dount know where they are ore haw to set them, any info will help thanks.:cool:
  2. Goozgaz
    Goozgaz
    I too am building a Rat Rod. Mine is a 87 Fierro with a fiberglass body kit that will make it look like Magnum PI's car. Then I will paint it flat black and then I will set it on fire so that I may have real flames as I drive it off a mountain and into the ocean.
    Welcome from the land of Goozgazia!
  3. TriFiveChevyJohn
    TriFiveChevyJohn
    from TEXAS!
    ROFLMFAO!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!:D :D :D :D :D
    Oh man...that was classic.:eek:
    Hey Rodereto,
    First try changinf your fluid/filter.
    Then check the:
    TV cable
    TV exhaust ball
    Throttle Lever/bracket assembly
    Oil pump (stuck pressure regulator, boost valve)
    Valve body assembly (Stuck TV valve, 2-4 servo/band, TV limit valve)
    Also while you're at it, check the governer & gov. filter
    If none of this works,
    Sell that piece of shit and buy a real car.
