killing time
Discussion in 'The Hokey Ass Message Board' started by pajet, Jan 13, 2012.
  1. pajet
    pajet
    from pa
    its 10 degrees here nothing to do but ponder. im putting a 41 ford together the rear tires are 235 75 15 and the rims measure 9.5 inches when straightedged from front to back. have 1 inch clearence from inside of tire to frame and the same on outside to fender. tread width is about 8.5 however it flares out at the sidewall. looking to get a little more tread on the road. am i right in thinking that if i reduce the rim width i could increase tire width. 235's measure 10" at widest point
  2. Blue One
    Blue One
    from Alberta
    A 235/75 R15 tire fits best on a 7" rim. And no, it's not a good idea to put a wider tire on a narrower rim.
  3. Johnny Gee
    Johnny Gee
    from Downey, Ca
    The question makes no sence. But a 235 is better suited to a 7" wide rim.
  4. Cutlassboy68
    Cutlassboy68
    from Boone, Nc
    a 235 is a 235 if its on a 2" wide rim or a 10" wide rim
  5. casper
    casper
    The proper way to measure the width of a wheel is from inside bead to inside bead. The section width on a 235 is 9.25" however the tire will wear the best on a 7" rim as stated above.
  6. pajet
    pajet
    from pa
    thanks for your response i did not set these tires up they came to me that way.was probably a ***** to get them on the rims non the less they are on them. my question was if i go to 8 inch rims could i use a wider tire. thanks
  7. pajet
    pajet
    from pa
    measured rim from outside bead to outside bead
  8. Johnny Gee
    Johnny Gee
    from Downey, Ca
    8" wheel = 275's
  9. pajet
    pajet
    from pa
    i understand that tread width of a 235 will not change but what about the section width? on a wider rim it would taper out from tread to rim and opposite on skinnier rim
  10. phat rat
    phat rat
    I run 255/60X15 on 8" rim on my 41 Ford cpe
  11. pajet
    pajet
    from pa
    thanks good stuff as usual. car wont be on the road till mid 2012. might ****can 9.5 rims go to 8" and up tire size. or burn off 235's first
