Projects Kind of a build Thread.... ish 28 RPU
Discussion in 'The Hokey Ass Message Board' started by Internet, Jun 6, 2014.
  1. Internet
    Internet
    All over the map with this truck, just use it to kill time. It's made up of cheap cl***ified site parts mixed in with left overs and give aways. I'm into it for under a grand just needing some decent front tires to make it a roller.
    The pics consist of making the front kicks, then the frame. adding 6" to the body and bracing it up. engine mounts from a set of 37 wishbones. First ***embly of the front suspension. Mystery to me front wishbones, quarter elliptical front suspension inside the frame and some wide 5's. dash is a swap meet item that was labeled '38 ford.
    I will update as I hurt myself, like I did this evening. Burned all the skin of my middle finger wire wheeling a set of reversed Buick/Ford wheels for my '31.
  2. sko_ford
    sko_ford
    Digging the dash &cab extension
  3. Internet
    Internet
  4. Internet
    Internet
  5. Internet
    Internet
    floooorsss.
  6. Internet
    Internet
    and the not hamb friendly part. what the best way to wake up a lumbering low compression FE?
  7. 55willys
    55willys
    Are you keeping the wide fives? If so **** Spadaro sells a nice adapter. Go for the turbo just watch the compression ratio and boost FE engines will ping on cheap gas. We had one with a water injection system on it that worked pretty well to deal the pinging
  8. Internet
    Internet
    7 1/2 weeks from a bare frame to burning tire, got it ready just in time for an end of summer bbq saturday. besides having to change just about every steering component length, it works fairly well. upper steering arm is much to short.
  9. rottenleonard
    rottenleonard
    Looks like fun. Turbos make good mufflers:D
  10. Internet
    Internet
    doubt the turbo motor will stay, thinking y block with pipes sneaking out from the frame kick, full hood and take the rear "deck" off and have a nice modified.
  11. 26 T Ford RPU
    26 T Ford RPU
    Interesting build, I feel it would look nicer if the front frame kick-up was just out of sight in the cowl. Cool all the same. JW
  12. Internet
    Internet
  13. Internet
    Internet
  14. Internet
    Internet
    it transformed..... the new owner of the rpu is a member on the hamb.
  15. colineunson
    colineunson
    from Victoria
    Update
    new owner here, picking up where it was left off
    rebuilt and added rear brakes
    then built box and channel for the wood deck
    added wood
    added some firestones, got the windshield cut, and added headlights
    all for now!
    bct likes this.
