Hot Rods Kind of a Dorky Hemi Adapter Question...
Discussion in 'The Hokey Ass Message Board' started by hellerlj, Jun 15, 2014.
  1. hellerlj
    hellerlj
    from Minnesota
    Early Chrysler Hemi's.....Extended Bellhousing
    Offenhauser Adapter to attach an early ford 3 speed ******
    Does anyone have a photo of this done ????
    Does the adapter but the ******, "INTO" the Bellhousing ???
    Or does it just make the Bellhousing that much longer ???
    I have attached a photo of the adapter...
    Sure would like to see what it looks like attached !!!!
    THANKS
  2. madmak95
    madmak95
    I dont know about that adapter but mine that puts a gm 4 speed is flat across the extended bell housing.
  3. sunbeam
    sunbeam
    I never understood more engine and then having to feather foot it to keep the drive train together
  4. Rusty O'Toole
    Rusty O'Toole
    I think your picture is for a later engine. The one you are referring to should be shorter.
  5. hellerlj
    hellerlj
    from Minnesota
    From what I can find on line and from old catalogs, the 0403 Adapter is for
    51-53 Chrysler V8's...A number of companies made these, and I am sure,
    some where taller or shorter then others....
  6. snaptwo
    snaptwo
    as the early Ford gearbox had an integral bell and the 51 -53 Chrysler had the long bell , the designers of those early adaptors did indeed position the box inside the extended Chrysler bell. Looked goofy but worked , at least for a brief moment !
  7. Hemiroid
    Hemiroid
    Lester...
    It mounts "INTO" the extended bell housing of the 331 Hemi and ****s the little Ford 3-speed box further into the bell.
    I can't locate my pics today but someone out there will help before I can find them!
  8. RichFox
    RichFox
    Back in my early days i had a long bellhousing Chrysler with a Packard transmission. The Offy adapter was flat. The adapter to mount the 39 type Ford transmission did indeed sink into the Chrysler bellhousing. Just like yours.
  9. hellerlj
    hellerlj
    from Minnesota
    Great info from all of you.....now if someone can just find me a photo...
    I appreciate ALL your Time and Expertise....
  10. Hemiroid
    Hemiroid
    Not really the pic I was looking for but it gives ya the idea...
  11. Hemiroid
    Hemiroid
    Ya know Les...
    I have a few old 3-speeds here if ya want to drop one in your adapter and take a pic.
    I even have a camera available.
    That extended bell is pretty deep. It will swallow the old torque converter without gagging.
  12. hellerlj
    hellerlj
    from Minnesota
    I know, I still have your empty housing with the crack.....THANKS..
  13. Atwater Mike
    Atwater Mike
    The housing on the early Ford ****** extends forward far enough to encase the relatively short input shaft, so what you are forced to do here is negate some outer housing length.
    The Packard box mentioned has a flat front 'wall', and a longer input shaft...so its adaptor for the long housing '51-'53 Chrysler is flat.
    The pic above shows an adaptor cast from an early Ford 4 speed, which essentially 'adds' a Ford clutch housing with its clutch cross shaft, Ford style...
    But an actual Chrysler to Packard would be a flat plate type, with the Packard drilling.
    I had a few of those long housing Chryslers with '37 Buick Roadmaster adapter, '37 Packard, and early Ford 'tunnel-type', and LaSalle.
    Ford trannies didn't last long... LOL
  14. hellerlj
    hellerlj
    from Minnesota
    Thanks again for all the education
  15. 73RR
    73RR
    The photos in post 9 are what you would have.
    As mentioned, the old ford box won't last long so be sure to have a couple dozen available....
  16. hellerlj
    hellerlj
    from Minnesota
    Thanks to all that chimed in....PLEASE DELETE !!!!!
  17. 62rebel
    62rebel
    don't delete! education is meant to be shared! i learned some things reading this.
  18. I did also!
