king pin questions ?
Discussion in 'The Hokey Ass Message Board' started by flatblak51, Mar 16, 2012.
  1. flatblak51
    flatblak51
    looking at my king pins on my 51 ford , the bearings are on top, what would be the reason for this ?
  2. hoggyrubber
    hoggyrubber
    i don't know about any ford, but my hudson has thrust ball bearings on the top of the kingpins to somewhat carry the load of rotation.
  3. BJR
    BJR
    Someone put it together wrong. The axle sits on the spindle, the bearing should go in between the bottom of the axle and the bottom of the spindle.
  4. tb33anda3rd
    tb33anda3rd
  5. Hnstray
    Hnstray
    from Quincy, IL
    Depends on the spindle/spindle support design. If the spindle support ("axle") sits in the middle and the spindle bosses are above and below, then the thrust bearing would be on the bottom.
    On the other hand, some spindle supports have the bushed king pin bosses above and below and the spindle sets in the middle. In that case, the thrust bearing would be on top.
    Ray
  6. flatblak51
    flatblak51
    car, coil spring
  7. tb33anda3rd
    tb33anda3rd
    weight sits on top of spindle
