kingdom for a bolt-
Discussion in 'The Hokey Ass Message Board' started by Ratpackin, Dec 30, 2008.
  1. Ratpackin
    Ratpackin
    It's the little s*** that always gets me.
    Any ideas where a guy might find odd sized bolts (without paying $9 shipping for a single bolt like at boltdepot.com). Looking for a 1/4"-20x5" with an allen head - that's the part that's making this difficult. -A standard bolt won't fit within the ribs.
    -Need to secure my dual-quad Moon air cleaner ***embly, now that I added a taller filter.
    -Thanks
  2. Phil1934
    Phil1934
  3. HOTRODPRIMER
    HOTRODPRIMER
    Do you guys in California not have a nut and bolt store or a Ace hardware?
    That should be a common item.
    Even in this small town we have 3 or 4 to chose from. HRP
  4. ray
    ray
    from colorado
    i find that hard to believe.
    i'd fire up the welder for an air cleaner hold down.
  5. fiftyv8
    fiftyv8
    from CO & WA
    Me To, get the welder out.
  6. tdoty
    tdoty
    Dude, ya got 10 Fastenal stores around Hayward!
    Here's one:
    25073 Viking St.
    Hayward, CA 94545
    P: (510)785-9991
    F: (510)785-9995
    1/4"-20 x 5" Alloy, Zinc Plated Socket Head Cap Screw
    Sku: 93223
    Package Quan***y: 1
    It's a stock item and it's listed for $1.78.
    Too much?
    1/4-20 x 5" Plain Alloy Socket Head Cap Screw
    Sku: 23223
    Package Quan***y: 1
    Also a stock item, lists for $1.31.
    This link will get you to a page showing all the Fastenal locations around Hayward: http://www.fastenal.com/web/locations.ex?action=search&zip=94540&state=
    I have 2 Fastenal stores nearby, one near where I live and one about 5 blocks from my garage.
    HTH,
    Tim D.
  7. Scott Danforth
    Scott Danforth
    Try ACE hardware if you dont want to go to Fastenal, or try www.mcmaster.com vs boltdepot
  8. moter
    moter
  9. HOTRODPRIMER
    HOTRODPRIMER
    ray,,what's so hard to believe?:confused: HRP
  10. Circus Bear
    Circus Bear
    Try finding a door hinge for a 47 dodge coupe. nope the sedan one won't work.
  11. Randaddy
    Randaddy
    You could use a piece of all thread, a small spacer and nut, but that may be too simple. Next find a machine shop and have them make you one out of stainless steel with a custom head, should only set you back $2-300,00
  12. Shifty Shifterton
    Shifty Shifterton
    Call first. The last time I walked into a fastenal store looking for an odd fastener they freaked about it being a non-commercial sale. And only sold the item after I whipped out a business card from a manufacturing company and insisted they'd sent me.
    Also look at the "nutsert" style things they sell at home improvement stores. The kind where you drill a hole in wood, then tap these in. One side is threads, one side is a decorative ****on. Point being, with many of those styles if you remove the anchor barbs, what remains is a closed head decorative nut, perfect for attaching an air cleaner lid.
    good luck
  13. tdoty
    tdoty
    Wow, I've never had any trouble buying stuff at Fastenal. Wearing my uniform shirt into the place might help though.........I dunno.
    Tim D.
  14. Old61
    Old61
    from PA
    Home depot also stocks allen head bolts.
  15. publicenemy1925
    publicenemy1925
    from OKC, OK
    At the bolt place's around here, they have a 5.00 dollar min. on what you buy.
  16. B.A.KING
    B.A.KING
    have to admit it ace hardware is a pretty good source for small parts:rolleyes:
  17. 48fordnut
    48fordnut
    I used to buy lots of stuff from fastenal, but now ,in my area its buy 100 or nothing.
  18. Rockettruck
    Rockettruck
    Similar to what Randaddy said, my solution was to use what hardware stores call a "coupler". It's like a tall nut, threaded all the way through, that allows you to screw whatever length of bolt you need in each end, after cutting one head off. Or you could use all-thread for the end that screws into the carb.
    I needed an air cleaner hold down bolt in a pinch several years ago--and it's still doing the job!
  19. gonzo87107
    gonzo87107
    Fastenal should NOT do that to you! I work for them and I never turn away anybody be it wholesale or retail. We don't have any rules against retail sales.
  20. JC Sparks
    JC Sparks
    from Ohio
    Everyone that builds anything at all should know about www.mcmaster.com, I build all kinds of industrial equipment and Mcmaster-Carr has all of the hard to get little parts and the big ones. If you live with in a few hundred miles of one of there shops the shipping is only 1 day.
  21. 40StudeDude
    40StudeDude
    Watch the bolts/nuts you buy there...they are made in China...the cheap ones will twist when you put any kind of torque on them...then break. If you're looking for bolts that will hold, go for the graded bolts.
    R-
