Gday Guys I'm ***embling the I beam front end on the roadster at the moment and am wonering exactly where the thin round shims and the felt washers go on the k'pins. Any help appreciated. Steve
got your bushings pressed in and honed to fit the pin? the thin washer with the lip goes on first - slide lip pointed down to top of pin then the felt washer then the pin goes in the spindle through the axle throught the bearing with open part of bearing point down then back through the spindle line of the notch and put in the pin do a search on kingpins - someone posted a diagram
