Technical Kingpin Bearings get Grease?
Discussion in 'The Hokey Ass Message Board' started by Crankhole, May 12, 2015.
  1. Crankhole
    Crankhole
    On early Ford kinpins, should the bearings be packed before install or do they get lubed via the zerks when pumped through the bushings?
  2. ROADSTER1927
    ROADSTER1927
    I grease them first when ***embling but yes they get greased from the zirk. Gary:)
  3. 302GMC
    302GMC
    from Idaho
    Fill everything full by hand before ***'y. If it moves, pre-lube it ....
  4. timwhit
    timwhit
  5. Crankhole
    Crankhole
    Will do, thanks.
  6. Anyone use that roller bearing update kit from Speedway ?
  7. Don's Hot Rods
    Don's Hot Rods
    from florida
    I've never used one of those roller bearing setups, but I have heard they aren't as good as one would think . Not sure why, but that is just what I have heard.
    Don
  8. seb fontana
    seb fontana
    from ct
    SSBC has a set that are nearly 100.00 [from memory] more than speedway's which might make them better.;)...I think the outer bearing shell may be too thin to take the pounding, causing the needle bearings to mark the shell and make it deteriorate, probably fine in the lighter cars..
    Vintage48 likes this.
  9. Kevin Lee
    Kevin Lee
    Super Moderator
    Roller bearings for kingpins present as a solution looking for a problem. I'd rather replace a two dollar bushing.
    When I look at big, old pieces of machinery like spinning lathes the shafts are running on babbit – not giant needle bearings. Add to that the time I've spent as a bicycle mechanic replacing headsets on road/triathlete bikes that became "indexed" from long straight miles on rough roads and you can keep needle bearings where they belong – Auto Union crankshafts!
  10. woodiewagon46
    woodiewagon46
    from New York
    I always pre lube everything. Grease like water will always take the path of least resistance. I have removed kingpins that one side was wornout and one side with plenty of grease. I always jack the front end up and turn it lock to lock and grease it like that. As far as the bearings, I know that bearings want to roll. Bearings that only move slightly, wear out faster than bearings that have hard use. A front end that only turns slightly might wear out the needle bearings. I like bushings for early Ford front ends.
