Kingpin Replacement
Discussion in 'The Antiquated' started by knuckle44, Dec 2, 2025.
  1. knuckle44
    knuckle44
    I am replacing the kingpins (spindle bolts) and bushings on a '47 Ford Pickup and have a couple of questions. What type of grease do you use for ***embly? I am thinking of wheel bearing grease as it may last where the spindle bolt p***es through the frame (which is where I had trouble driving the old ones out).
    The existing spindle bolt p***ed through a thick washer and then into the top bushing. The kit has a dished washer and felt washer and I ***ume these replace the thick washer. Should I reuse the thick washer or convert to the dished and felt washer?
    down-the-road likes this.
  2. If it is still in good condition,use the original Ford washer
  3. Fordors
    Fordors
    The dished washer and felt is as originally used by Ford, it provides for grease retention. Someone subs***uted those thick washers at some point in your trucks life.
    down-the-road and leon bee like this.
