1952-59 Ford Kovid Kustomline build thread
Discussion in 'Off Topic Hot Rods & Customs' started by Dos Cincos, May 20, 2013.
  1. tcoupekyle
    tcoupekyle
    well, I’m not exactly a wealth of knowledge on the subject but what I do on my dragster and helmets and stuff I’ve painted is I use the 3 inch tape to make straight lines, it’s easier to lay straight cause it doesn’t like to curve and has wrinkles if it curves. then I lay fine line next to it to to keep a sharp edge. My problem is consistency making the angles the same. I think next time I do a lay out I’m going to bolt 2 paint sticks together to use as a protractor. To match the sides. I also sometimes use a stabilo pencil to make small Marks and I’ll measure and Mark with the stabilo but, stabilo doesn’t like to wipe off of primer so I only use it on something that’s been cleared and sanded.
    Idk if that’s much help though.
    down-the-road and Dos Cincos like this.
  2. guthriesmith
    guthriesmith
    I just pull tape long distances if possible. I have been doing custom paint since I was 14 using fineline tape to do the masking. It’s not too bad to make straight lines if you just start in one spot and pull it straight before before sticking it down. Not sure if that makes any sense, but is how I try to do it. I haven’t done scallops in several years, but have done lots of flames. Don’t need any straight lines in flames.
  3. Dos Cincos
    Dos Cincos
    Thanks guys for the tips. I've been doing most of these already but am mostly struggling with the shapes of the scallops. My engineering background says there is a mathematical calculation for how long, wide, inner/outer curve dimensions and it really isn't playing out that way. It has been more of lay the tape down and look, pull it up and try it again until it looks right.
  4. Dos Cincos
    Dos Cincos
    I'm struggling with the inner scallop layout. Part of me says the tail is too short. Part of me says the layout needs to go in a different direction to better match the outer stripe. Thoughts?
    56longroof likes this.
  5. tcoupekyle
    tcoupekyle
    I dig it. I like how the center line sort of flows into the other line. My .02
  6. Dos Cincos
    Dos Cincos
    I fixed what was throwing my eye off. The outer edge of the scallop needed to be parallel to the outer edge of the center stripe. Also needed to be a tad longer. Next step is to get it masked and painted. 20230920_171944.jpg 20230920_171956.jpg 20230920_172007.jpg
  7. guthriesmith
    guthriesmith
    Yep, I agree with the lines needing to be parallel like you changed it to. That made a big difference.
    Dos Cincos likes this.
  8. tcoupekyle
    tcoupekyle
    Oooh yes yes I agree! Great work!
  9. Dos Cincos
    Dos Cincos
  10. tcoupekyle
    tcoupekyle
    Yes!! That looks killer!!
  11. Dos Cincos
    Dos Cincos
    Amazing what a few rattle cans and rolls of tape can do for the overall look of a car. 20230923_133300.jpg 20230923_133325.jpg 20230923_133357.jpg
    Finkeetiki jay, Zax, bobss396 and 5 others like this.
  12. tcoupekyle
    tcoupekyle
    Awesome man
  13. 56longroof
    56longroof
    Very nice!
  14. greaser 35
    greaser 35
    from FRANCE
  15. guthriesmith
    guthriesmith
    Yep, made a big difference and turned out great! :cool:
  16. Dos Cincos
    Dos Cincos
    Nothing new. Just back from a long late afternoon drive and thought the cherry tree in my driveway made a good backdrop.
  17. tcoupekyle
    tcoupekyle
    You’re right! Looks killer
  18. Dos Cincos
    Dos Cincos
    Turns out - replacing the driver's side door hinge pins makes a WORLD of difference in how it closes.
    The old upper on the left and lower on the right. No slop in the hinge afterwards and the door closes solidly. 20240407_135812.jpg
    And a video of it closing. A little harder than needed but I shut it with my foot while holding the camera still
    https://youtube.com/shorts/aM6LkTaDDhg?feature=shared
    down-the-road, T Hudson and Zax like this.
  19. Dos Cincos
    Dos Cincos
    The Hotrod Reverend inspired me to stick my GoPro under my car for a cool video. This proves that I have the Kustomline as low as you can go and still drive it without airbags.
    #dirtybecauseitsdriven
  20. danman55
    danman55
    Great video and nice angle! What shocks are you running?
  21. nosford
    nosford
    So, what is the gold colored object seen bouncing around at the top right of the picture? That car would not do the roads around here this year, it is the year of the pothole!
  22. Dos Cincos
    Dos Cincos
    It is the front sway bar bushing. I noticed that too when I first viewed the video and checked on it. It is most definitely bolted down. My GoPro mount is a long plastic arm that is more flexible than the metal setup the Hotrod Rev used for his new rear shock video. I have the camera set to image stability but I suspect it is only applying to images at the center of the screen
    nosford likes this.
  23. Dos Cincos
    Dos Cincos
    Thanks! They are the KYB gas adjust shocks - KG4503. Pretty sure they were the recommended ones in the sticky for lowered cars
    danman55 likes this.
  24. KG4503 + CC850 Spring... Good Combo.
    danman55 and Dos Cincos like this.
  25. slider-ok
    slider-ok
    from oklahoma
    just got done going thru the whole post your doing a great job
  26. Dos Cincos
    Dos Cincos
    Thank you. I really appreciate the compliment!
    tcoupekyle likes this.
  27. Dos Cincos
    Dos Cincos
    Dad and I at a car show yesterday.
  28. tcoupekyle
    tcoupekyle
  29. mikhett
    mikhett
    from jackson nj
    I'm looking for that side trim you have on your car.What is it off of and where can I purchase.thanks and love you car !
  30. Dos Cincos
    Dos Cincos
    Thanks! The side trim is nothing special, just stock 1955 Customline trim
