1952-59 Ford Kovid Kustomline build thread
Discussion in 'Off Topic Hot Rods & Customs' started by Dos Cincos, May 20, 2013.
  1. Dos Cincos
    Dos Cincos
    Got the caps on and had to pull her out of the garage and grab a quick picture.
    I also added a kool sticker I found on the internet.
    redzula, Texas57, Rui and 8 others like this.
  2. guthriesmith
    guthriesmith
    Looks great! And, love the sticker!
    Dos Cincos likes this.
  3. 56longroof
    56longroof
  4. greaser 35
    greaser 35
    from FRANCE
    Look kool with a lancers caps!!!
    56longroof and Dos Cincos like this.
  5. You are not far from me. I'm at Rockmart. Trying to get started again on a '55 Fairlane 4 door that my parents bought new. Mine will be running the 272 and 3 on the tree, just a few mild custom touches like shaved hood and deck lid with a solenoid to pop the trunk, '56 Fairlane backup lights. I think of the 3 on the tree as an anti-theft device since not many people alive today know how to drive one. Car was originally white with green interior. Painted it metallic gold in '68 and interior in black roll and pleat. Keeping the interior which is still good, going with black/yellow 2 tone. Never saw the bumblebee 2 tone on a 4 door but there were a few. Lots of bumblebee Crown Vics and convertibles.
    danman55, Texas57 and Dos Cincos like this.
  6. earthbound
    earthbound
    Looks great!
  7. Dos Cincos
    Dos Cincos
    JeffB2, redzula, St.Eriks and 2 others like this.
  8. I just found your build thread! Subscribed...
  9. redzula
    redzula
    Just got my 55 today. And as the guy was explain how the trunk latch opens funny I noticed what looks like #9 fence wire connecting the lock to the latch. Thought it was just a janky DIY fix but seeing yours that looks exactly the same... Are those wires just how they were from factory? I like your fix with the emergency release would work well for a full shaved trunk too I'm sure.
  10. Dos Cincos
    Dos Cincos
    Yes, that is how they came from the factory. Only a small press on lock washer deal holds the linkage in place. That washer is what keeps sliding off on mine which is why I put the cable in. Im now seriously considering shaving the trunk with this backup cable in place.
  11. redzula
    redzula
    I would.... I wasn't planning to shave mine ever it at least not for a while but that's a clean way to do it and now I'm thinking about it lol
  12. jailbar joe
    jailbar joe
    many years ago when was kids...we used the solenoid of a starter for a electric trunk opener
  13. JeffB2
    JeffB2
    from Phoenix,AZ
    Next time you guys are out in a U-Pull-It Salvage yard look for a 1998-2002 Daewoo they had a trunk cable that had a lever that mounted on the floor along side the front seat that might be a good alternative.
  14. Dos Cincos
    Dos Cincos
    I've been making my way around the car knocking out dents and creases and have thus far been able to get, the ones I can get to on both sides, to where they will take very little body filler to get perfect. I'm not 100% sure the best way to tackle the ones which fall where two panels meet and the factory seam sealer is in place in the rear quarters. Are these worth s****ing the seam sealer out or should I just put some body filler on them and move on?
  15. evintho
    evintho
    Can you get a small prybar down there to pop the dent out from the inside while hammering the outside? If not, you can always tack a finish nail to the center of the dent and pull. They make a special tool for that but a welder will work just fine or.....just fill with filler. The dent looks pretty small.
    guthriesmith and Dos Cincos like this.
  16. Texas57
    Texas57
    The stud welder from Harbor Freight works very well, but the slide hammer that comes with it does not. Eastwood sells a good slidehammer. IMG_4592.JPG
  17. guthriesmith
    guthriesmith
    I use a stud welder like Rich mentions or sometimes just even tack a piece of steel to the area to pull. I tried a stud welder on a late model recently and it wouldn’t stick. Had to just get the mig out and tack a piece on that I could pull on. But, from what I see, the dents you are showing can just be filled with no issue at all.
    Texas57 likes this.
  18. Dos Cincos
    Dos Cincos
    Thanks guys for the responses. The ones I showed are a good representation of the ones I have left so I most likely will fill them and move on.
    Texas57 and guthriesmith like this.
  19. Texas57
    Texas57
    That'll be just fine on what you showed us, just make sure you clean them out really well with a wire wheel before filling. Also clean with wax and grease remover before applying filler anywhere.
    guthriesmith likes this.
  20. Dos Cincos
    Dos Cincos
    The plan I have been working lately is to work a panel out to where I am comfortable with it, getting it down to bare metal, and then spraying it with epoxy primer. I'll then go back later and add filler on top of the epoxy with a primer seal coat on top of the filler after that. Is that okay or should I be putting the filler directly to the bare metal and adding the epoxy over that?
  21. guthriesmith
    guthriesmith
    I have always applied filler directly to the metal. That method has worked well for me for almost 40 years now. But, I know some folks do that different, so I can’t speak to how that works.
  22. evintho
    evintho
    Yep, when I worked in body shops in my late teens/early twenties we'd grind the metal with 36 and slap on some mud.
    Oh.....how times have changed!
  23. Texas57
    Texas57
    It's apparently done both ways now, but I'm a bare roughed-up metal guy myself. If I find an area that may not finish up with high build primer, and decide to add some filler over the epoxy, I use the lighter glazing stuff that's like a lighter version of regular body filler. I use Rage Gold for filler, btw, and NEVER NEVER use the one-part glazing stuff in a tube. If you use a glazing material, always use a glazing that needs the hardner.
  24. Dos Cincos
    Dos Cincos
    I plan on using this and will try y'alls method of adding it directly to the metal and then spraying the epoxy over the top. I have to make a rust repair to the lower rear quarter first though.
    Texas57 likes this.
  25. nosford
    nosford
    Rage gold is worth the little extra money, I agree, it works and is easy to feather out.
  26. Dos Cincos
    Dos Cincos
    Been awhile since I've posted an update on my progress. It has been slow and mostly body work lately so not much to share. This weekend I was able to get the hood, cowl, and drivers fender all in primer and also got the inside of the hood in paint. Putting the filler down before the primer is definitely the way to go. Thanks for the tip.
  27. evintho
    evintho
    That car is definitely coming along! I like it!!
    JeffB2 and Dos Cincos like this.
  28. Texas57
    Texas57
    Looks great. Nice work.
  29. okiedokie
    okiedokie
    from Ok
    Good to see your progress.
  30. 56longroof
    56longroof
    Love the Savoy grill.
