1952-59 Ford Kovid Kustomline build thread
Discussion in 'Off Topic Hot Rods & Customs' started by Dos Cincos, May 20, 2013.
  1. Dos Cincos
    Dos Cincos
    Rear seat panels are almost finished. I am missing the p***enger armrest so if anyone has an armrest and/or the ashtray for the p***enger side they would be willing to let go, let me know. Also, got her out yesterday at lunch.
    bobss396, 40FORDPU, Rui and 6 others like this.
  2. orangedog
    orangedog
    I'm jealous. Keep em coming.
    Dos Cincos likes this.
  3. Dos Cincos
    Dos Cincos
    Scored a box of arm rests from my dad which had the missing p***enger side front and back that I needed. The Ash tray cleaned up nicely. Also took the wife and dog out for a first day of spring ride.
    Rui, 56longroof and nosford like this.
  4. Dos Cincos
    Dos Cincos
    After 8+ years of usage, it was time to replace the flexible exhaust tubes running from the headers to the mufflers with some hard pipe. Also ran the exhaust all the way to the bumper instead of ending at the rear axle. Very pleased that I can now have a conversation in the car and no longer smell of exhaust after a ride.
    Rui, bobss396, nosford and 5 others like this.
  5. Dos Cincos
    Dos Cincos
    Was able to get both door panels finished up and installed today. Hard to get a good picture of the zodiac flake but it pops. Thankfully I have enough material left to make some kick panels next. Is everyone using velcro to hold them in place? Also, what is the trick to getting the bolt out of the hand strap for the backseat? 20220325_172551.jpg
  6. Zax
    Zax
    Door panels look great! My kick panels are held in place by a channel on the door side. I can grab a pic tomorrow if it would help. May be different on yours.
  7. okiedokie
    okiedokie
    from Ok
    I have door panels and kick panels held in place with Velcroe in my 53 F100 and it works good. It is the heavy duty industrial stuff.
    down-the-road and Dos Cincos like this.
  8. Texas57
    Texas57
    Velcro strips in my '57 as well. Used it to replace the OEM style snap-in clips.
  9. Dos Cincos
    Dos Cincos
  10. Dos Cincos
    Dos Cincos
    redzula, 56longroof, bobss396 and 2 others like this.
  11. guthriesmith
    guthriesmith
    Looks good and does make a difference that will stand out even more once you get it blue! :cool:
    Dos Cincos and the-stig like this.
  12. 40FORDPU
    40FORDPU
    Coming along nicely.
  13. Dos Cincos
    Dos Cincos
    Thank you sir.
    And thank you sir
  14. evintho
    evintho
    Door panels = very, very nice! Also, if you paint the car the same color as your window frames, those white fenderwells are really gonna make the car pop!!
  15. Dos Cincos
    Dos Cincos
    Thank you! Yes, the plan is for the car to be very similar to the window frames once finished.
  16. 56longroof
    56longroof
  17. Dos Cincos
    Dos Cincos
    Fairlane 62, 56longroof, Zax and 6 others like this.
  18. orangedog
    orangedog
  19. Dos Cincos
    Dos Cincos
    The Kustomline ran pretty hot the last time I had her out so I decided it was time to drain and flush the cooling system. Started off by draining the old coolant which was fairly nasty.
    Then I added some ThermoCure to the radiator and ran it for three hours over several days to clean out all of the rust from the system. Then drained that and back flushed the whole system.
    This is the ThermoCure results.
    After the back flush I replaced the thermostat (180°) and added a sacrificial anode in place of the pet**** valve on the radiator.
    Took her for a spin and she holds at just a tick above 180 with no leaks so I'm calling it a win. Probably need to look into an actual shroud for the electric fan next to help with long Atlanta stop lights.
    bobss396 likes this.
  20. okiedokie
    okiedokie
    from Ok
    Yes on the shroud.
  21. bobss396
    bobss396
    I put a sacrificial anode in my radiator, figured after 3 years I'd buy some fresh zinc pieces. I took the old one out... It was perfect, but I put in a new one since I had 5. Probably the ground strap on the radiator to the support helps.
  22. guthriesmith
    guthriesmith
  23. Dos Cincos
    Dos Cincos
    Quick update. Local Goodwill store had two rear seat grab straps keenly disguised as a woman's belt. For $3.00 I was able to get both straps out of it.
  24. Dos Cincos
    Dos Cincos
    Took the Kustomline out to a local show last weekend, just to have the small 90° byp*** hose from the thermostat housing to water pump burst upon parking for the show.
    Needless to say, all of the recently added coolant went everywhere in the engine compartment. Thankfully the local parts store had what I needed and I was able to drive her home.
    A byproduct of all of that was forcing me to do some badly needed engine bay cleanup. Some of which I already knew from my post in the engine thread.
    Before:
    After:
    Still more to be done but it is an improvement.
    bobss396, danman55, nosford and 3 others like this.
  25. Zax
    Zax
  26. evintho
    evintho
    Good call on the seat grab straps! Great use of repurposed materials!
  27. Dos Cincos
    Dos Cincos
    Been chasing an overheating issue, or at least a perceived issue (hard to tell when it is +95° with humidity just as high). I wound up dialing the timing back to 10° and then leaned up the carburetor a tad more and also decided to swap the radiator cap back to the 16 psi cap that came with the radiator instead of the one I had purchased from Amazon that was rated for 14-18 psi (not sure that 2psi really would affect the temp). The changes seemed to help keep the temp down while running around and stop light to stop light traffic but now I'm wondering if the cap had any effect or if it was all just in the timing/carb adjustment?
    Also, found this cool old church round the corner from me that looked like it fit the era of my car so stopped for a quick pic and then muted the colors a bit for a more vintage look.
  28. danman55
    danman55
    Dos Cincos, can I share that photo of the car in the church parking lot on my website with your permission? I would be glad to give credit to where credit is due...
    guthriesmith likes this.
  29. Dos Cincos
    Dos Cincos
    Wow, absolutely. Will be interesting to see how you use the picture. Thanks!
  30. danman55
    danman55
    Later this summer I will have a blog post showing a lot of the rides and some of the other work that guys are getting done. I do appreciate it - and nice job on those colors!
