Krylon primer and paint for suspension and rear axle?
Discussion in 'The Hokey Ass Message Board' started by 56 ford custom, Mar 29, 2013.
  1. Dan in Pasadena
    Dan in Pasadena
    Man, is it ever!
    The prep must have been DAMN good to end up with that!
  2. Gearhead Graphics
    Gearhead Graphics
    from Denver Co
    Ive started using the "appliance epoxy" for all my hard use items, works like a dream
  3. dsprint2000
    dsprint2000
    Have used basic Krylon for decades. Never a problem and looks fine - easy touch ups too.
    David
  4. MoparJoel
    MoparJoel
    Painted my 8.75 rear with gloss black krylon over 5 years ago, It has been my daily driver ever since and still looks as good as the day I painted it.....
    Uploaded with ImageShack.us
  5. need louvers ?
    need louvers ?
    Yep! Straight out of the can. No prep work other than to scuff the tanks down with a red scotchbright pad on a brand new radiator. 'Course, I've emptied a can or two of spray paint in my day! But really, this stuff is a little heavier than the standard Rust-O-Leum and much heavier than krylon. It shoots beautifully and lays down very nicely and is rock hard. Elpolacko and I have been using it on chassis stuff for years now.
  6. blowby
    blowby
    from Nicasio Ca
    Super! 85 and you warmed the can?
  7. 56 ford custom
    56 ford custom
    from Socal
    There you have it! I am going to continue to use krylon like I have been.
  8. Have you thought about brushing on a good quality chassis paint. It will be much cheaper to start with and there is no paint loss through over-spray.
    I did my O/T cyclecar in Tekaloid (a commercial vehicle coach enamel) and it looks like it has been powedercoated - the paint is formulated so that brush marks drop out.
  9. oakmckinley
    oakmckinley
    I just did my rear end in the basement this winter, and used the duplicolor rust- fix stuff. Seems pretty good, it hardened to a black color and was very easily painted over.
    Of course I'll no for sure when I reinstall everything and put it to the test in the elements.
  10. need louvers ?
    need louvers ?
    Yup! The only time I don't warm the can is when it's 115 or so around these parts; 85 around here is damn near jacket weather... I always run my sink in the kitchen as hot as it will go and let the cans soak for about 10 minutes before I shoot. I hear guys always talk about spray cans sputtering and clogging among other problems, I just don't ever seem to have. Heating the paint up seems to let it flow and lay down lots better too.
  11. rfraze
    rfraze
    We have had GREAT luck with Krylon for suspension parts. Quick dry time is my favorite feature, which allows you to recoat several times for better appearance and longevity. If you use the regular Krylon, you can choose a semi-gloss option (black is #1613). They used to offer a semi-flat number which was a touch glossier than primer, but less than semi-gloss, which I haven't found in a while. If I have the gloss/flat thing backwards, as to what is still available, just look for the number. Get several cans, you will like it!!!
    Rattlecan 101: Clear tip after use by spraying upside down til color stops coming out, wipe tip.
