L78-15"s
Discussion in 'The Hokey Ass Message Board' started by swade41, May 28, 2010.
  1. swade41
    swade41
    from Buffalo,NY
    I finaly found a pair of 50 merc rims so I made the move to L78's on the T. I had 16 X 4.5 ford truck rims with 6.50 X 16 4 inch wide whites before. I like the new look of a bigger tire back there, now to find a couple more trim rings.
    before
    after
    before/after
  2. MrModelT
    MrModelT
    Nice lookin' T! Who did you get the L78's from and what tire/wheel size you running up front?
  3. swade41
    swade41
    from Buffalo,NY
    The L78's are Coker cl***ics bought them through Universal Tire since Coker didn't come to the Dunkirk,Ny swapmeet last weekend. The fronts are 5.60 X 15's Coker cl***ics on a 50 chevy rim 15 X 5.
  4. ratster
    ratster
    looks better bro. i have them on my roadster and run them at 26psi for a softer ride
  5. Tony
    Tony
    Nice change Phil.
    I ran the L78's on both my old truck and 32. They are a natural out back with 15" rims..
    The T looks perfect with 'em.
    Tony
  6. swade41
    swade41
    from Buffalo,NY
    Tony what rim width did you have on the truck ? Last time I was behind Mike they looked wider, figured it must be a wider rim.
  7. Tony
    Tony
    15x8 on both the truck and coupe. I liked the way the tire filled out with the wider rim.
  8. swade41
    swade41
    from Buffalo,NY
    Well these are only 5 1/2, now I see...lol
  9. olskoolspeed
    olskoolspeed
    from Ohio
    That is one bad *** ride. Very cool.
  10. Tony
    Tony
    Yeah but they do fit the look of that car real well. I'd leave em.
  11. 3wLarry
    3wLarry
    from Owasso, Ok
    yep ^^^^^
    kidcampbell71 likes this.
  12. swade41
    swade41
    from Buffalo,NY
    Yeah I'm done with tires, gotta get another bullet and trim ring and that'll be that. I'm still thinking about that model A shell for up front but I think the radiator might be a bit tall for it.
  13. Mr48chev
    That looks slick with the bigger tires on the back. I like the idea of swapping the A grill shell on it if you can figure out how to make it look right.
  14. howco
    howco
    no doubt, the L's look much better........
  15. swade41
    swade41
    from Buffalo,NY
    Yeah that's the problem, I can only lower the radiator about an inch because it's right over the pitman arm. If the top of the radiator isn't below the cowl then I won't change it, the system works good now running 180-190 all day long.
  16. edweird
    edweird
    hey man, that's probaly the best lookin T i've ever seen!
  17. Greezy
    Greezy
    Definately looks much better.
  18. swade41
    swade41
    from Buffalo,NY
    thanks man, there are a lot of great looking T's out there though
