L78 Max Wheel Width?
Discussion in 'The Hokey Ass Message Board' started by 1096, Jul 20, 2005.
  1. 1096
    1096
    Does anyone know if a L78 Firestone will fit a 10 inch wheel?
    Thanks in advance
  2. What I'm going to tell you is probably absolutly wrong but usually don't try and run wheels wider than my treadwidth.
    That said an L78 should run fine on a 10" rim.
  3. BLAKE
    BLAKE
    The rears in this pic are L78's on 8" rims... they may fit on a wider rim, but they won't look right. I agree that best rule of thumb is to use the tread width to determine rim width if you want them to look decent.
  4. Badfella
    Badfella
    What rim/tire size are the fronts in the pic?
  5. Mutt
    Mutt
    Here's a 10" rim against a L78 tire. I wouldn't do it. 8" max.
    Mutt
  6. BLAKE
    BLAKE
    Fronts are 15x5 wheels with 5.60-15 tires.
  7. checking the Coker Tire catalog , they recogmend L 78's to be on rims 6.5 to 9 inches wide
  8. Corky Coker
    Corky Coker
    from Tennessee
    According to the Tire and Rim ***ociation books, the approved rims for a L78-15 is 6, 6 1/2, 7, 8. Now...sometimes its fun just to break the rules! The dilemma you get into with running wider rims than recommended is funky tire wear not to mention the funky way the tire looks.
  9. Berdoo John
    Berdoo John
    Well no offense but I had an L78 mounted on a 15x8 wheel and I thought it looked awful.
